Suspension M7 spring
Old May 19, 2007 | 11:18 AM
lunlun's Avatar
lunlun
M7 spring
I have a local dealer who sells M7 spring.
However,
there seems to be no one using M7 spring....
why??
i thought they are progressive rate spring and supposed to be better?!?!
Why does everyone seem to use either Eibach or H-sport
Old May 21, 2007 | 08:08 AM
pauliekeys's Avatar
pauliekeys
There are lots of people using M7 springs. You need to read the tons of threads regarding M7 springs. It does seem that H-sport springs are used by more people then the other brands. I've just switched from H-sport springs to M7's and the verdict is still out. I ran the H-sports for about two years and I liked them (performance wise) very much. The M7 springs seem to feel about the same as the H-sports but the M7's lower the car just a tad more. I do feel like there is "something" different but I can't put my finger on it. I need to get out in the twisty's a bit more before I decide to keep them. I truly liked the H-sports but wanted to be a bit lower. After trying this spring experiment, I think I will start saving up for coilovers and get what I should have gotten in the first place to truly achieve what I want to do with the performance and look I'm after.
Old May 21, 2007 | 11:55 AM
minimarks's Avatar
minimarks
Just a note...the lower you go, the more adjustment you will need in your suspension.
Old May 21, 2007 | 02:39 PM
lunlun's Avatar
lunlun
What do u mean more adjustment?
do u mean the rear control arms?
Old May 21, 2007 | 03:15 PM
lunlun's Avatar
lunlun
Do you all just avoid speed bumps or can you manage over them?
thanks!
Old May 21, 2007 | 07:49 PM
minimarks's Avatar
minimarks
Yes lower control arms...but the lower you go you may also need upper contol arms and adjustable camber plates for the front end, etc.... The lower you go, the more it effects all the settings in your suspension. There is a good article in issue 6 of MC2 magazine on suspension basics that I think explains things pretty well for us novices. Might be worth a read.
PS: Don't get me wrong, I,m not saying there is anything wrong with M7 springs. Everything that I've heard about them has been positive.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
