Suspension balance
Old May 15, 2007 | 10:45 AM
justintime's Avatar
justintime
balance
So, I was wondering about this the other day. Which car between the cooper and the cooper s is better balanced through the corners? is there enough weight diference/distribution to matter?
Old May 15, 2007 | 11:20 AM
meb's Avatar
meb
I would almost agree to write that the difference between runflats on the S and non-run flats on the Cooper will make a bigger difference...and steering feel is not a run-flat strength.
Old May 15, 2007 | 12:16 PM
Beecher's Avatar
Beecher
there really shouldnt be too big of a difference. I mean an s has the supercharger up front, while a cooper has a battery. Not sure how much the SC weighs tho, the batter is like 35lbs. And a cooper doesnt have the bat in the back, and if you didnt take your spare out, they are probably balanced about the same. I would also venture to guess that getting a light weight battery and removing the back seat, although would throw your balance out, you would gain more from the lack of weight than that you would loose from "worse" balance.
Beecher
rt808
Sep 25, 2015 01:59 PM
JBsC6
New York/New England
Sep 24, 2015 02:41 PM
JBsC6
Sep 15, 2015 09:58 AM
ShadyCoop
Sep 11, 2015 11:14 AM
renchjeep
Sep 6, 2015 01:54 PM
