Drivetrain compressing rear wheel caliper piston?
Old May 11, 2007 | 09:29 AM
LBE's Avatar
LBE
All right, whats the trick? Did the front brakes no prob. The rear caliper piston does not want to go in? Am I missing something? is there a tool? or do they turn in? The piston does not appear to be frozen, just does not go in.
03 Cooper S, not JCW
Old May 11, 2007 | 09:31 AM
Partsman's Avatar
Partsman
Legion_of_Doom
The rear caliper piston does thread in.
Old May 11, 2007 | 09:42 AM
TonyB's Avatar
TonyB
There are several threads on this topic in the wheels/tires/brakes forum. Some of have had pretty good luck with a large C clamp (as PARTSMAN said, it needs to spin while compressing). Harbor Freight has or at least had a cool 10 buck compression kit, and it worked wonderfully for me.
Old May 11, 2007 | 09:47 AM
Partsman's Avatar
Partsman
Legion_of_Doom
The search function works well.
I use a C-clamp, it works well, as long as the screw and the little thing on the end spin together.
Old May 11, 2007 | 10:20 AM
JCWGrover's Avatar
JCWGrover
If you have an Autozone, Advance Auto or similar parts store in your area, they usually have the tool you need as a loaner. Much better than buying one you'll only use so often, and the price is right. Free!!
Old May 11, 2007 | 10:51 AM
TonyB's Avatar
TonyB
If you have a HF near you, I'd recommend the 10 bucks, if still available. I've used mine 5 or so times in the last 2 years, and on all of our cars. Free is great of course too! I'd rather have something that I can use whenever I want, and not hassle with driving back-and-forth somewhere (lost time), and with what gas costs now, it might not be as all that "free" in the end...
Old May 11, 2007 | 11:51 AM
norm03s's Avatar
norm03s
This belongs in the other forum but if you need to buy a C clamp be sure to get a 6" one.
Tony, you got that on sale from HF, they normaly go for $39.xx bucks. I know, have been waiting for them to go on sale again!
Old May 11, 2007 | 08:06 PM
ScottinBend's Avatar
ScottinBend
Just go to your local HF and tell them you saw it on sale last week and they will most likely sell it to you for the $19.99 price.
Old May 11, 2007 | 10:04 PM
norm03s's Avatar
norm03s
They don't carry that kit at my local HF.
Old May 12, 2007 | 05:10 AM
cristo's Avatar
cristo
Alliance Member
You can also push it in while turning clockwise with a set of needle nose pliers.
Put the tips of the pliers into the two recesses, then push while turning.
Old May 23, 2007 | 02:01 PM
norm03s's Avatar
norm03s
Yep thats the way I started them moving then used the C clamp.
Bingo, the HF brake kit was just on sale with an email coupon for $15.99!
Located a new larger HF store, went right down and got one.
squawSkiBum
Oct 2, 2015 09:21 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
StealthR53
Aug 8, 2015 10:59 AM
