Drivetrain Calling all Cali Modders
Old May 10, 2007 | 07:20 PM
koogzah's Avatar
koogzah
So has anyone had any smog issues after going big on the top end? I'm talking porting, oversize intake valves and cam. Would love to go in that direction but am a little wary of the CARB *****. I am currently running the 210 JCW and would probably not go with a smaller pulley, although I could be convinced...
Any experiences/advice would be greatly appreciated. Thanks!
Old May 10, 2007 | 09:15 PM
SharoSC02's Avatar
SharoSC02
find a tuner that can adjust some things for you.
Old May 10, 2007 | 09:20 PM
koogzah's Avatar
koogzah
Hmm. So you're saying that a properly tuned car with a big valve head would not pass then? You'd have to flash the ECU with a super lean map before testing, then go back again afterwards?
Old May 10, 2007 | 09:42 PM
El_Griton's Avatar
El_Griton
or move. Thats what I did
Old May 10, 2007 | 10:01 PM
koogzah's Avatar
koogzah
So far I am not hearing encouraging words... I have grappled with the Smogmen before, and they are most hateful creatures.
Old May 10, 2007 | 11:19 PM
SharoSC02's Avatar
SharoSC02
Where in cali are you? If you can get to San Jose area I will get you to a shop that will pass your smog.
Old May 10, 2007 | 11:33 PM
koogzah's Avatar
koogzah
I'm nearby and will definitely let you know if I need a mod-friendly smog shop. No need to smog yet, just thinking through the implications of doing a big head.
Old May 10, 2007 | 11:57 PM
latte hiatus's Avatar
latte hiatus
We need to compile a list of mod-friendly smog testing services.
Old May 11, 2007 | 12:20 AM
SharoSC02's Avatar
SharoSC02
I've done a big head with this shop as well and it should be ok with the smog. I have an 1987 325i convertible that I had done all sorts of mods to it and no one in town could come close to smoging it untill I took it to this shop that does all my Mini mods.
Old May 11, 2007 | 09:25 AM
LBE's Avatar
LBE
You obviously didn't live in Cali. Why would anyone leave?
Old May 11, 2007 | 10:12 AM
70spop's Avatar
70spop
Oh.... you were serious? It would be hard to leave, but there are sure a lot of things I wouldn't miss.
Old May 11, 2007 | 10:27 AM
luckydoggarage's Avatar
luckydoggarage
OBD2 and you
Most states that do smog testing use the OBD2 portion of the factory ecu to determine if the car passes or not. If the vehicle has a problem with fuel trim or cat effic. then this will be detected when the monitor status is checked at the inspection station. There is a certain condition where all the internal tests have run their course and passed for the car to pass. If you clear your codes to turn off the light the monitors will not have been run to completion and the car will fail. Proper tuning is required to achieve max output as well as operating parameters that are within oe specs. Piggy backs will not do this, only proper ecu reflashing.
Old May 11, 2007 | 10:54 AM
jymontoya's Avatar
jymontoya
Why I'm happy to be in a no emissions or inspections area.... Ahh, thank you southern east coast.
TonyB's Avatar
TonyB
Good info, thanks LDG! By any chance, do you have someone who you can recommend in the NorCal?
Old May 11, 2007 | 11:41 AM
SharoSC02's Avatar
SharoSC02
same shop that I recomended to the thread starter in San Jose.
elverado
Jan 18, 2022 02:51 AM
shahriar35
Sep 14, 2015 11:53 PM
Sep 10, 2015 10:52 AM
Panik
Sep 9, 2015 08:36 AM
