Drivetrain Fidanza flywheel and OEM clutch
Old May 8, 2007 | 06:02 AM
Fisher's Avatar
Fisher
Hello,
does go together this two things?
I am going to change the flywheel I would like to know if the OEM clutch belong together?
Old May 8, 2007 | 06:51 AM
k-huevo's Avatar
k-huevo
The Fidanza flywheel is un-sprung; it requires a sprung hub clutch disc. The S model’s flywheel is a twin-mass (sprung) design which uses an un-sprung clutch disc. So, if you have an MCS, the stock clutch disc is not compatible with the Fidanza (at least not without drivability issues).
Old May 8, 2007 | 07:03 AM
Fisher's Avatar
Fisher
Hello.
Yes I know that the OEM flywheel is twinmass to reduce the vibrations.
So if I change it to fidanza it will be in any case more vibrations. But I am looking that picture of OEM clutch in ETK and it has a springs. Like all "normal" clutch.
If I look that "sport" clutch it hasn't got springs, so there will be a driving issue.
Ma plan is: Fidanza flywheel, OEM clutch(disc) with beter (carbon) mass on it and OEM plate.
So the "biggest" question is does go the OEM plate to fidanza flywheel (interspace of the bolts)?
I hope I was clear.
Old May 8, 2007 | 07:38 AM
k-huevo's Avatar
k-huevo
To restate your question as I understand it now; will the OEM R50 Cooper pressure plate bolt holes and dowel holes line up with the Fidanza flywheel? Sorry, I do not know that answer. You may contact Fidanza and pose that question to them, or restate your question in the “non-S” forum section for possibly better results.
Old May 8, 2007 | 07:46 AM
Fisher's Avatar
Fisher
U sorry, I am talking about COOPER S 2002.
Old May 8, 2007 | 08:07 AM
k-huevo's Avatar
k-huevo
You want to combine a flywheel designed for the S model with the sprung hub disc & pressure plate designed for the Cooper (according to the diagram photo provided); that’s why I suggested the “non-S” section to increase exposure.
Of course if we keep bobbing this on the top of this section long enough someone who knows will be able to see it and answer .
Old May 8, 2007 | 09:34 AM
Fisher's Avatar
Fisher
I really don't understand what are you talking about.
Here is the link to OEM clutch:
http://www.realoem.com/bmw/showparts...76&hg=21&fg=05
Where do you se "non S section"?
Old May 8, 2007 | 02:06 PM
Fisher's Avatar
Fisher
Now I have do some research.
In the ETK is the wrong picture. You have right, the OEM clutch do not have a springs.
A little anoying.
Old May 8, 2007 | 02:40 PM
k-huevo's Avatar
k-huevo
I called MINI Mania 1 800 94MANIA and talked to Dennis @ ext.47; he said the stock R50 Cooper clutch and pressure plate will fit the MCS model Fidanza flywheel.
Old May 8, 2007 | 08:45 PM
J Propane's Avatar
J Propane
The stock pressure plate will fit a Fidanza flywheel.
Just make sure they send you the right bolts with it. Don't assume they'll fit.
(I don't mean to say there are more than one spec of bolts; just that there are stories out there of receiving the wrong bolts in the package)
Old May 9, 2007 | 01:23 PM
jymontoya's Avatar
jymontoya
I almost did this myself when the dealer was replacing my clutch and flywheel under warranty.
I didnt because I heard from 4 different MINI tuners that unless you use the RPS (dual mass flywheel) You'll have a BAD noise coming from the combo everytime you take off from a start.
andrewjg1994
Jan 29, 2021 07:45 PM
Branto
Aug 11, 2017 05:32 PM
blackie
Oct 2, 2015 07:41 PM
Camaro108
Aug 25, 2015 02:44 PM
FLYM1N1
Aug 16, 2015 01:15 PM
