Drivetrain Do I need a JCW charger belt with a 15% pulley
Old May 8, 2007 | 05:26 AM
fozworth's Avatar
fozworth
Ive just got a 15% charger pulley and would like to know if i need a JCW charger belt as im worried a standard one will be to long
Old May 8, 2007 | 05:31 AM
MINISQL's Avatar
MINISQL
Standard belt should work just fine. Shorter belts are required for 17% and 19% pulleys.
Old May 8, 2007 | 06:37 AM
Fisher's Avatar
Fisher
It's work with standard belt but it's better to get a shorter one.
Old May 8, 2007 | 08:28 AM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Helix has the right belt, the JCW will cost a wacking load more. If you live in the Bay Area I have one w/ a used Helix pully for cheap, under a $100 and very low miles.
Old May 8, 2007 | 02:08 PM
Crashton's Avatar
Crashton
I've been using the stock belt with an Alta 15% for 15,000 miles or so with zero problems. That being said I'm about to change to a JCW belt soon.
Old May 8, 2007 | 03:55 PM
Guest's Avatar
Guest
It will work fine with the stock belt . A shorter one will fit better, but I don't see how it could do anything to help unless your belt was breaking like mad.
iamcamkeenan
Aug 10, 2015 03:31 PM
Lt. Dan
Aug 10, 2015 12:46 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
