Beware on fiberglass front ends.
Old May 7, 2007 | 12:25 PM
Xanthus's Avatar
Xanthus
Coordinator :: South East - Florida
Beware on fiberglass front ends. Mine was so misshapen that I have had to have it reworked a bunch.
BEFORE:
This is the work in progress:
http://www.tamparacing.com/forums/el...ml#post4125013
Old May 7, 2007 | 12:34 PM
xsmini's Avatar
xsmini
It's looking better I was wondering about that fit when you first showed those pics before. What a pain in the a$$.
Nik
Old May 8, 2007 | 02:35 PM
Xanthus's Avatar
Xanthus
Agreed, I was most dissapointed with the bonnet.
Old May 8, 2007 | 03:44 PM
elprofe's Avatar
elprofe
HOW DID you attach the upper trim of the grill?
Old May 8, 2007 | 06:27 PM
Xanthus's Avatar
Xanthus
I will have to take pics when I pick her up this weekend.
Old May 19, 2007 | 04:06 PM
Xanthus's Avatar
Xanthus
So I get the bloody thing fixed and then the hinge point gives out.
In sharp contrast to the quality in every other thing I ordered from Minitec the fiberglass front is garbage.
Old May 19, 2007 | 11:32 PM
elprofe's Avatar
elprofe
I CAN'T believe they went to fiberglass mount when they used to be metal.
there is too much stresss there and fiberglass will give no matter how thick it is.
Old May 20, 2007 | 06:52 PM
Xanthus's Avatar
Xanthus
no it was aluminum..... hinged on a STEEL THREADED BOLT.
Same issue though.
Old May 20, 2007 | 07:06 PM
elprofe's Avatar
elprofe
how tight was the bolt?
are you saying the aluminumb broke?
Old May 20, 2007 | 08:18 PM
Xanthus's Avatar
Xanthus
Yes, THIN aluminum will not swivel around a threaded steel bolt without wearing down the metal.
It was not tight, as it was intended to function as a hinge. That is the real crux of the issue. It's a poor design choice. I had reinforced the other side with steel, and was intending to do the same on this side, but id broke prior to getting around to the fix.
Just happy there was no additional damage to the paint from it.
Old May 21, 2007 | 09:14 PM
elprofe's Avatar
elprofe
WOW, THAnks for the tip, I'll to reinforce mine.
BTW if you have not done so, you'll need to upgrade those cheap shocks that will not hold the hood up.
Old May 22, 2007 | 08:32 AM
Xanthus's Avatar
Xanthus
Thanks, I will keep that in mind also.
Old May 29, 2007 | 08:51 AM
IanF's Avatar
IanF
How difficult would it be to convert it to hinge forward?
Mini7
Feb 2, 2016 07:52 PM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
