In-car video recommendations
Old May 30, 2006 | 11:31 AM
  #26
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Originally Posted by nethack
I had seen a bunch of people that used some sort of rod and ball-mount device attached between the head-rests of BOTH seats. I didn't like that idea as I thought that the camera would bounce enough without it getting extra input from my fat a$$ in one of the seats. Here's my solution (worked OK)...
Make sure you don't have the window up and close the door
I don't know how much you're willing to spend but there's a product out there called a CruiseCam that runs about $45 and attaches to the headrest bars of a seat to secure the camcorder. It's similar to the mount you made with the monopod, except it doesn't require zipties.
Old May 30, 2006 | 11:46 AM
  #27
nethack's Avatar
nethack
For just that fear I installed the mono-pod from the back seat with front passenger door closed and the window up... just to make sure it fit Don't need no broken window The only real problem I had was that, initially, I didn't tighten the ball mount enough. I hit an expansion joint and the camera flopped over. I found a safe place to pull over and fixed it. As soon as I learn how to use the video editing software I'll post some shots.
Old May 30, 2006 | 07:40 PM
  #28
tsukiji's Avatar
tsukiji
WARNING:KIDS, DON'T TRY THIS AT HOME!
Old May 31, 2006 | 11:13 AM
  #29
OctaneGuy's Avatar
OctaneGuy
A couple of things
Nethack you got a PM
Second, is anyone using a DIY headrest mount also running a Schroth harness? Since it runs under the headrest, my own prototype mount wasn't usable since it blocks the path of the harness.
Richard
BennyF
Oct 21, 2015 12:54 PM
kohlersc
Sep 28, 2015 09:49 AM
FatherG
Sep 20, 2015 08:26 PM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Gremothra
Sep 9, 2015 08:42 PM
