Microphone?
Old Aug 9, 2013 | 08:26 PM
ChicagoRus's Avatar
ChicagoRus
Microphone?
I have my GoPro mounted to my tow hook. The video looks great but there's little sound, so I was going to add a Microphone at the exhaust (running a cable between the two). Does anyone have any recommendations for a good microphone? I've never used an external Mic on my GoPro before so any advice is greatly appreciated.
Old Sep 4, 2013 | 11:39 AM
Craig Curtis's Avatar
Craig Curtis
You cant hook a gopro and a mic together. But you can have an external mic and sync it in editing. Zoom makes a few good (and inexpensive) ones
Old Sep 4, 2013 | 11:49 AM
walkinghispath's Avatar
walkinghispath
The gopro records in stereo. So you can actually record two different tracks and flatten the audio in iMovie or whatever you use. I have one mic wired to the intercom system of an aircraft and the other records ambient sound. If you just want car noises you'd be better served putting the mic in the engine bay (near the intake). Exhaust is usually too low of a note to record and reproduce well. Plus, you'll get the SC/turbo, intake, and BOV/bypass valve sounds. For a really trick effect hook up mono mics in the engine bay on the left and right side of the car. The result will be like you're there.
As for which mic to use, there are lots. Check out some video forums. You want something good at ambient noise so performance mics are not ideal.
Old Sep 4, 2013 | 11:59 AM
Craig Curtis
Yea but have you ever HEARD the audio from a gopro? garbage! Really, its barely useable for anything other than to use as a garbage reel for timing with an external mic.
Old Sep 14, 2013 | 06:13 AM
ChicagoRus's Avatar
ChicagoRus
Thanks for the suggestions. I hadn't really heard the audio from a GoPro with a microphone attached, so I guess I have to start by looking there. It was interesting what you said about mic-ing the interior (under the bonnet). I really hadn't thought of that, but I will now. Thanks folks! I appreciate all of the help.
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Sep 7, 2015 11:27 AM
timwhayden
Aug 24, 2015 08:42 PM
jbing
21
Jan 2, 2014 07:20 AM
Coffeeman
58
Mar 10, 2011 11:48 AM
