Marketplace - Archive Old Marketplace threads and posts (Read-only). Please use appropriate Marketplace forum for new posts.
November Mini Prize Give Away
Old Oct 24, 2002 | 08:03 AM
PaulaAlibrandi's Avatar
PaulaAlibrandi
Minicooperparts.com would like to offer a November 15th drawing for all members on the forum. We will announce the winner's name here on the 15th. We would like to give away the complete set of the vent grill covers pictured on our website -- exterior parts - vent covers section. Simply e-mail us with your name and address. As a sponsor of the site our goal is to send a hard copy of our catalog to everyone on the site.
Paula Albrandi
http://www.minicooperparts.com
e.alibrandi@att.net
Old Oct 24, 2002 | 09:16 AM
Davbret's Avatar
Davbret
...you've got mail!
R
Old Oct 24, 2002 | 10:19 AM
PaulaAlibrandi
I've received a couple of questions about installation of the aluminum grilles. Here is a copy of the instructions that come with them. When a local Mini guy comes in we install the entire set in 15 minutes. Probably would take you 30 minutes the first time. Anyway in the Miami area gets free installation.
Bonnet Grill: - Present the bonnet grill to the inside part of the hood noting the slots cut for the plastic tabs. Once in place, use the supplied zip ties to secure the grill, Place the zip ties behind the painted sections of the hood to conceal them.
Radiator Grill: - Present the aluminum grill over the existing plastic grill. Drill small holes into the solid ends of the existing grill and secure with the supplied zip ties.
Lower Vent Grills: - Remove the lower shroud. Visually locate the plastic vent tube located behind the bumper. Apply silicone to the concave portion of the aluminum grill. Insert the grill behind the bumper with the concave portion facting towards the rear of the car. Attach the grill to the vent tube and allow the silicone to dry. Reassemble.
Intercooler Grill: - Looking at the underside of the hood, remove the four bolts used to secure the plastic housing. Present the aluminum grill to the front opening in the housing and bend the aluminum, towards the back, over the top part of the plastic housing. Reassemble.
Fresh Air Vent Grills - Use a flat piece of plastic (i.e. Credit Card) to depress the three front retaining clips on the bottom of the existing plastic grill. There is one in the middle, and the other two are at each end. Once this is done you can pull the plastic grill up and out to remove it. Once removed, you need to seperate the two pieces of plastic holding the foam insert. Pressing the retaining clips located on the underside of the plastic grill does this. After the two pieces have been seperated, remove the foam insert and replace it with the aluminum grill. Reassemble.
Old Nov 14, 2002 | 06:56 AM
PaulaAlibrandi
The winner of the give away is Jon Chan in Bedford, MA and your grilles will be shipped today.
Please see the Home page for a December giveaway of a Mini electric cooler.
Paula Alibrandi
Finish Line
Old Nov 14, 2002 | 10:21 AM
docjchan's Avatar
docjchan
Thankyou, I can't wait to put them on.
iggi
18
Feb 9, 2026 01:00 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
arf88
May 31, 2016 03:07 PM
Terry J
Aug 11, 2015 09:39 AM
bc219
Aug 10, 2015 11:22 AM
