Looking for blow off valve
Wanted
Engine - Intake/Fuel
    $100 - $225
  • Location Orange, CT, 06477, USA
  • Condition New or Used
  • Compatibility
Make Model Year
Mini R58: Coupe 2014
Any one selling a blow off valve for 2014 coupe jcw ?
thank you
Old Nov 20, 2025 | 10:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I wouldn't bother with a used valve. Just get this one:
https://www.ecstuning.com/b-pierburg...658636606~pie/
Old Nov 20, 2025 | 10:35 AM
Meanygreenie's Avatar
Meanygreenie
thank you , appreciate it !
im looking for a blow off valve like a turbo smart , for the sound -
Old Nov 20, 2025 | 10:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Add one of these, and call it a day:
https://www.ecstuning.com/b-torque-s...-r56-bovs~tor/
Old Nov 20, 2025 | 12:06 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I've tried both turbosmart b0v , the ebay ones and some other name brand like the ebay ones and they ALL lost power. The most effective thing to do is upgrade the spring in the stock divertervalve and I also found the aftermarket k04 turbos NEED a turbosmart wastegate actuator to get the turbo to spool down low enough.. the provided actuator doesn't have enough adjustment...
​​elps.hope any of that helps.. heres my currentbuild btw.. als0 a 13' jcw...
Old Nov 20, 2025 | 12:19 PM
Meanygreenie
hey ! Good to know - that sucks to lose power I thought they help with the turbo protecting it a bit but also gaining the nice sound - but not worth it if it loses power -
the turbo wrap in your picture is that a specific part that it’s exactly ? Where do you get that - is it an improvement ? Thank you
Old Nov 21, 2025 | 09:34 AM
MiniManAdam
Community Builder
ecs,ebay ,amazon ect..sells them.. it's a turbo blanket, I need it because I couldn't run stock heatshield with my ko4 turbo and tubular exhaust manifold.
Old Nov 21, 2025 | 09:39 AM
MiniManAdam
Community Builder
Actually a bov puts excessive stress on the turbo. Once it blows off ( looses spooling) like between shifts , your turbo has to work that much harder to makeup for that...
our turbos don't function like most turbos , with their internal vacuum operated wastegate it changes things..
