Coding in Madison
Coding in Madison
I may not be checking this board or PM very often so please contact me at -> bmwminicoding [at] gmail [dot] com
The following options can be coded
Doors & Mirrors
• Close Windows & Roof / Convertible top with the Key FOB.
• Unlock doors when the ignition is turned off
• Disable Auto Dimming mirrors
Wiper Operation
• Wiper completes the cycle when ignition is turned off
Rain Sensor
• Close Sunroof when the rain is detected (Rain Sensor should be turned on)
Instrument Cluster
• Disable Door Chime when the key FOB is in the slot.
• Instrument Cluster Lighting always On (Day & Night)
Lights
• Double Blink Hazard lights
• Disable windows safety feature (One touch window rolls up when door is open)
• Fog Lights stays on with high beam or high beam flash
• Fog lights always on with headlights (low beam, Auto)
• Follow Me Home Lights (Turn on low beam and break lights when trunk release button pressed once - FRM3)
• Delete Bulb Errors (Disable Cold/Warm Test after Retrofit)
• Adjust the Auto Light Sensitivity (Head lights will not turn on when it is sunny)
Seat Belts
• Remove Seat Belt Chime for Driver and Passenger
Others
• Retrofit Coding
Doors & Mirrors
Wiper Operation
Rain Sensor
Instrument Cluster
Lights
Seat Belts
Others
• Retrofit Coding
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
