JCW Suspention or H Springs
Originally Posted by supersand
I don't have any suspension upgrades but read these boards quite frequently/ obsessively and it seems the consensus is that the Billstein PSS9 are they way to go... although they are more expensive than the JCW suspension they do give ride height and dampening adjustability.
The originator didnt say he was racing. Per "Randy" and I quote http://store.webbmotorsports.com/ind...in_page=page_3
"You may notice that I didn't recommend installing coilovers. While the ultimate in handling can be had with coilovers, the truth is that they are bigtime overkill for 95% of MINI drivers."
It's definelty more money but it does give you more options for adjustments in the future if you want. The JCW is already $900 plus installation the Billsteins are $1500-1600 so it is a $600-700 premium (assuming equal installation times) but gives you more. But thats just my opinion I may be wrong... Personally I think the stock sports suspension is fine for street driving.
Originally Posted by Kellzir
How much does the dinan suspension lower the car???
Originally Posted by ScuderiaMini
How about the Koni FSDs with JCW springs? Would be an ideal set up, i guess.
Why would one mix JCW springs with Koni FSD dampers?
Mixing springs and dampers is necessary when buying a spring from one manufacturer - who has not developed a matched damper - or vise versa. The JCW kit is a matched kit.
Presumable the FSD's work with stock spring length and rates. The JCW springs are shorter and heavier...perhaps not by much.
meb, you are right, the idea of marrying the JCW springs with Koni FSDs is to have a little bit lower car. But thinking of more, 10mm drop is barely visual, so dunno if it is worth going the extra mile.
dyeLucky
Aug 7, 2015 07:10 AM
