JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Wire Identification
Old Jun 2, 2022 | 04:32 AM
EastTNMini's Avatar
EastTNMini
Wire Identification
Can someone tell me what the wire is for that enters the front of my drivers side brake caliper? Thanks to all.
Old Jun 2, 2022 | 05:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
That's the brake pad sensor. When the pad wears down, the sensor breaks contact, and the car tells you to service your brakes.
Old Jun 2, 2022 | 05:27 AM
Jason Cornelius's Avatar
Jason Cornelius
That doesn’t need to be installed back into the pad, just zip tie it up and out of the way. It isn’t too hard to peak through the rim and see what your pad thickness is, at least front side, and I check them again every 5k when I’m rotating tires.
Old Jun 2, 2022 | 05:40 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I'd say that, if the OP didn't know that it was the sensor wire, he should keep the sensor in place. Also, he should be aware that there's one on the left rear caliper as well.
Old Jun 2, 2022 | 06:27 AM
EastTNMini's Avatar
EastTNMini
Thanks everybody. Noticed the one on the back as well while I was changing out all 4 ABS sensors. One at the front is almost broken in half which is why I posted question. How does car notify you when brakes need replaced..... indicator light?
Ian7689
May 23, 2022 01:34 PM
Ninima
Apr 15, 2022 10:26 PM
morphix
May 12, 2009 09:47 AM
qwertmonkey
Jun 6, 2006 07:44 AM
