JCW When do GP's appear?
Old Aug 14, 2021 | 10:04 PM
El_Jefe's Avatar
El_Jefe
Question When do GP's appear?
I am noticing that whenever i look for a mini, or build one on the site, there is never a GP version to be had.
Anyone know when they come out or if they do?
Old Aug 15, 2021 | 05:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The GP's are special edition models. GP1 and GP2 were last year of the current hatchback model. (R53 and R56) I believe Mini plans to have the GP as a last year model special build. At least, that is the internal plan. The F56 model was extended with a 3rd LCI version after the GP3 was deep into its release, which makes the 3rd generation hatchback a special case.
I wouldn't expect to see another GP model for quite some time.
Old Aug 15, 2021 | 05:32 AM
JackMac's Avatar
JackMac
GP1 - 2006
GP2 - 2013
GP3 - 2021
GPE - 2024 (just a rumor, possible electric)
You won’t find them on the configurator, they cannot be built or ordered. You basically reserve one in advance or perhaps find one on a dealer lot which was unsold.
Old Aug 16, 2021 | 07:16 AM
TheGeekGuy's Avatar
TheGeekGuy
There is one at MINI of Monrovia:
MINI GP3
Old Aug 16, 2021 | 09:54 AM
TheBigNewt's Avatar
TheBigNewt
The GP3 is basically the same platform (engine, 8 speed automatic tranny, brakes,) as the JCW Clubman and Countryman in a hatchback body, without the All4 and back seat and without the adjustable dampers option, with slightly wider wheels/tires and different suspension parts. For $45k.
Old Aug 16, 2021 | 11:19 PM
El_Jefe's Avatar
El_Jefe
Jeez it has a sad automatic in it.
Thank you for the info. I am from old era minis where most were manual and fully customizable. Hm.
JCW hardtop is where it is at I guess!
Old Aug 19, 2021 | 12:16 PM
TheBigNewt's Avatar
TheBigNewt
The GP3, the JCW Clubman and Countryman models are the only Mini models that are really BMW platforms with Mini bodies. It's the M235i BMW model (not sold in the US). Which is an automatic transmission. The GP3 doesn't have the ALL4 (Clubman and Countryman do have it, so does the BMW). The JCW Hatchback and the Cabrio still have the manual option. They have less powerful engines though.
Old Aug 21, 2021 | 10:23 PM
Clutch Wotan's Avatar
Clutch Wotan
Thanks to the BMW construction kits, the GP3 is the best GP and more than customizable MINI ever since !
- the engine is the catch, the missing rear wheel drive safes weight and extra cooling. The automatic is fine.
You can drive it as a daily eye catcher as the previous ones and you can score on trackdays right away and overlap a JCW Clubman with the same engine every 4 minutes
Old Aug 22, 2021 | 11:19 AM
El_Jefe's Avatar
El_Jefe
automatics are [term deleted]
Last edited by 2017All4; Aug 23, 2021 at 09:51 AM. Reason: deleted inappropriate terminology use
Old Aug 23, 2021 | 05:46 AM
DunkM's Avatar
DunkM
automatics are [deleted]
You’ll never see me in your slow AF manual.
I will leave this up, but it is awfully cruel without the rest. Either way, I like manuals, but the amount of people who **** on the automatic in the GP without even trying the GP specific software is way too high. Both are viable options; go give it a try!
Last edited by DunkM; Aug 23, 2021 at 12:02 PM. Reason: deleted comment on the intelligence of a fellow poster
Old Aug 23, 2021 | 09:54 AM
2017All4's Avatar
2017All4
Super Moderator
Keep it civil!
Old Aug 24, 2021 | 04:13 AM
Clutch Wotan
Put it that way if you use the GP for Racing only, you get a fine a working option ex factory, which can handle the torque, even for 350hp. If you are not happy you have 2 options - Install a race transmission, or do a upgrade forge on you manual piece by piece.
The 2nd option you could use on a daily GP3 as well, a bespoke race transmission is not drivable in public traffic, so the Aisin with a modified Drexler LSO is 24hour fit and appreciated.
minim8o
GP Talk (2006)
30
Feb 3, 2010 03:31 AM
howsoonisnow1985
Aug 14, 2008 07:14 PM
KTrout
GP Talk (2006)
Aug 26, 2007 04:34 PM
lastrega
GP Talk (2006)
17
Dec 11, 2006 12:45 AM
MOTORN
GP Talk (2006)
50
Oct 18, 2006 02:26 PM
