JCW 2012 jcw sound system and visual boost
Hello,
I am on the verge of buying a used 2012 jcw n14 manual with no harman kardon sound system or visual boost.
I would like to ask if hk is superior to have over regular sound system And does having screen actually gives any benefit like checking fault codes and stuff.
Car has fairly low mileage (15k) and is very clean. So i don't want to miss it if those things doesn't matter that much.
It's going to be my first mini, hopefully.
Thank you
Thank you
My 2 cents - if you listen to any music I'd recommend the HK over the base stereo, it would cost much more to upgrade later down the line. Sure it's not a Burmeister or anything but it's good for what it is and I don't feel the need to upgrade.
Re: visual boost, I would get it because I think you can't get bluetooth audio without it. For fault codes I think the same info you can find in the tach computer generally (won't have the nice UI).
Car looks very clean, but if you can find a 2013 with the updated N18 engine that is more likely to last you much longer than the problematic N14.
Navigation & Audio Help for Retrofit Navigation System instead of Visual Boost
Siempre
04-26-2016 02:17 AM
mbatech
09-10-2015 03:40 PM
Navigation & Audio DAB to 2012 cooper with visual boost and nav
dbdecker
03-16-2015 10:43 PM
Navigation & Audio Viseeo Tune2Air and Visual Boost or Nav - Can someone clarify?
Bossworld
02-14-2015 03:06 AM
3cyl
07-22-2014 12:34 PM
