JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Which clutch for jcw clubman
Old Jan 12, 2019 | 04:32 PM
furnitureman9's Avatar
furnitureman9
2009 clubman jcw manic stage 2 tune.
My clutch is on its way out and I need to decide which clutch package to go with. Should I go with something better than stock or will a stock clutch be ok? I searched online for answers but did't find much info. Any advice will be greatly appreciated.
Old Jan 13, 2019 | 10:14 AM
oldbrokenwind's Avatar
oldbrokenwind
Really happy with my OS Giken clutch / flywheel. Had it for about 50K miles and 7 years --- still looking good (just did an engine rebuild). Pedal is slightly stiffer, but not objectionable. Insignificant "chatter" when engaging. Well worth the high price. Suggest their LSD too, "while you're in there".
Old Jan 13, 2019 | 02:45 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If the car is a daily driver the original will be the smoothest and easiest to drive.
https://www.waymotorworks.com/oem-cl...-cooper-s.html
The giken will hold more power, but is designed not to slip and isn't as smooth to drive daily as the clutch grabs quick.
https://www.waymotorworks.com/os-gik...-cooper-s.html
But the other big thing is to go ahead and put a real LSD in while you have the trans out. This way you can get the power to the ground.
https://www.waymotorworks.com/quaife...ferential.html
also put in the powerflex control arm bushings when you pull the subframe as it will be easy at the same time
https://www.waymotorworks.com/powerf...7-r58-r59.html
Old Jan 18, 2019 | 04:58 AM
furnitureman9
Great info guys!
Is changing the LSD necessary? Do they wear out? Or does changing from a stock LSD to quaife make that much difference?
Old Jan 18, 2019 | 11:14 AM
oldbrokenwind
LSD is not necessary, just a great improvement in handling and performance. They should only wear out under extreme track use. My OS Giken has been pushing 360+WHP for a few years, but on the streets, minimal track. As long as the tranny is out, this is a good and cost-effective time to do this mod.
DreamMini
Oct 15, 2011 11:55 PM
Ohmen
Detailing 101
11
Jan 7, 2010 06:54 AM
erwinito
Oct 4, 2009 05:42 PM
amdoubleu
Tires, Wheels, & Brakes
Apr 14, 2008 11:20 AM
