JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Alta intake tube
Old Oct 7, 2018 | 12:03 PM
Jcw'11's Avatar
Jcw'11
Alta intake tube
How good is it? Is it better than the silicone hose? Trying to see if I can cut some cost.
Old Oct 12, 2018 | 07:35 AM
ohiojcw's Avatar
ohiojcw
I like mine, very well made, easy install and looks good.... I had a silicone setup from FORGE before this one... ditched the forge unit because i didnt like the way the PCV was routed and was gonna be a mess of ugly fittings to run my catch-can setup....
I have noticed more intake noise from it than i did on the forge unit (not that thats a bad thing, lol)
Old Oct 18, 2018 | 07:49 AM
Jcw'11's Avatar
Jcw'11
Thanks for reply bro... more intake noise is wanted lol. How did you remove the mass airflow sensor part to intake? I cant seem to get it off plus I dont wanna damage anything. Hey this shop is charging me 600 bucks for installation of jm ici pipe... heatshield... alta inlet hose for turbo and oil change is that to much? I can probably do the heat shield and alta inlet pipe myself to cut some cost
Old Oct 18, 2018 | 07:50 AM
Jcw'11's Avatar
Jcw'11
What intake you running? The reason I'm upgrading is leaking and cracked intake tube
Old Oct 18, 2018 | 08:01 AM
cornjuice's Avatar
cornjuice
dont do it. Alta is the devil.
*look up "#airifix" on IG.. dude just came out with the full kit for R56.. same intake setup as the DS3. Its legit AF!
Old Dec 28, 2018 | 10:21 PM
Skidude's Avatar
Skidude
If you run the AEM cold air intake, the Alta inlet doesn’t fit exactly right. The bend in the inlet is incorrect. It’s not off by much but it’s annoying to look at and know it’s not quite right. It does the job just fine though. Also, the small port near the turbo can be a bit aggravating to get the rubber hose over it.
Old Dec 29, 2018 | 01:26 AM
Jcw'11's Avatar
Jcw'11
My alta intake is in my mail now cant wait to get it installed... remember remove the hood scoop barrier and you will see posted gains
ROOSEY
Jun 3, 2013 05:12 PM
Dead Ringer
R55 :: Clubman Talk (2008+)
Nov 21, 2008 09:40 AM
joshK
Jan 1, 2008 11:01 AM
4GAZM
Aug 17, 2007 01:35 PM
