JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Do I have the same turbo as the MCS?
Old Jan 24, 2017 | 09:01 AM
TheBigNewt's Avatar
TheBigNewt
Someone on the F56 forum said yes, but as I recall someone also said that with the N18 engine the JCW had a different turbocharger, not just an ECU tune. Maybe I got mixed up with the N14. Who's right? Thanks in advance.
Old Jan 24, 2017 | 09:27 AM
DneprDave's Avatar
DneprDave
John Cooper Works MINIs have a larger turbocharger and a lower compression ratio than the Cooper S Minis.
Old Jan 24, 2017 | 10:15 AM
TheBigNewt's Avatar
TheBigNewt
So that is true for both the N14 and the N18 JCW cars? There was some change made in the JCW models between those engines.
Old Jan 24, 2017 | 05:42 PM
DneprDave's Avatar
DneprDave
Yes it is true for both N14 and N18 engines. The turbochargers have different part numbers.
Here is the real oem site, it lists part numbers and prices for all BMW products.
You can check for yourself.
http://www.realoem.com/bmw/select.do?
Old Jan 25, 2017 | 01:46 AM
cerenkov's Avatar
cerenkov
The S turbocharger is a 37mm and the JCW is a 40mm.
The part numbers between the N14 and N18 turbos are also different, I'm assuming that the N18 turbos were slightly updated internally. They will all bolt on to any N14, N18 motor. The only thing to watch out for is the intake tube opening has a slightly larger diameter for the JCW versions, this should be replaced if upgrading to the JCW turbo.
