JCW Dropping JCW with DCC
Old Mar 22, 2016 | 06:52 PM
reRESERVEDMD's Avatar
reRESERVEDMD
Hi there,
Exactly what it says in the title... Is it ok to just do lowering springs, and if so, which ones do you recommend?
CORRECTION: Meant to say DDC
Old Mar 26, 2016 | 08:09 AM
Ryephile's Avatar
Ryephile
As long as you're aware you're eliminating most of the compression travel and it'll be riding on the bumpstops, the dampers will be fine, it's not relevant if they're DDC or standard. The car will also not be as composed in bumpy corners since there will be virtually no compression travel.
Old Mar 27, 2016 | 02:53 PM
blue al's Avatar
blue al
Eibach Pro-Kit Tieferlegungsfedern MINI F56 John Cooper Works - E10-57-004-05-22
These might be an option as its only 15-20 mm drop,
Nb they have other ones with a bigger drop, so double check part numbers
I'm considering some for my own car with DDC,
as I'm not keen to pump big cash into coilovers if you cannot change from stock camber
Old Feb 14, 2019 | 10:47 AM
YSoBlue's Avatar
YSoBlue
Lowering Springs with DDC
Let's bring this back out again....now that there are a few more years of "testing". Any issues with installing lowering springs on JCW with DDC. I have heard everything from reduced lifespan on the shocks to introduction of bump steer. <---seems unlikely.
What say those who have lowered their JCW...with DDC?
Old Feb 14, 2019 | 03:36 PM
elsnaibs's Avatar
elsnaibs
Any time you add lowering springs to standard shocks, there is a high chance of early failure due to reduced travel. I have the Eibach springs on my JCW (non ddc), and I am already saving to get a set of Koni Yellow Sports to replace the stock shocks when they fail. The handling has been amazing with the Eibachs, though, totally worth it. With the bump steer, that probably depends on how much you drop the car. The Eibach is only about 1 inch, and I have had no issues with that, or hitting the bump stops.
Old Feb 20, 2019 | 12:45 PM
Clutch Wotan's Avatar
Clutch Wotan
Eibach works fine with DDC
https://www.facebook.com/f56.shiva/photos/a.1569909749893124/2090627337821360/?type=3&theater
Old Feb 21, 2019 | 04:45 AM
RLM's Avatar
RLM
I've got my 16 JCW dropped on NM springs. the car sits nice now, I cut down the front bump stops as suggested in the instructions, but didnt have time to cut down the rears. so far no issues and not riding on the stops. DDC still works great. Mid mode is like sport was, and sport is now more of a sport plus. Bump steer is unchanged, but handling is way better. better road feel as well. only time will tell how the shocks hold up. I got my car in april with 20K km on it, now sitting at 45K km. when they go, Ill throw yellows in.
BucksCountyR57
Mar 1, 2018 07:21 AM
Mini_Vinnie
Suspension
19
Aug 24, 2016 11:19 AM
Buggy
Tires, Wheels, & Brakes
Jun 16, 2016 07:23 AM
Alpha Motoring
May 8, 2016 10:45 AM
midwestinsocal
Mar 18, 2016 10:35 PM
