JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW How to remove the Inlet hose 10 JCW
Old Jun 26, 2014 | 03:54 PM
'10JCW's Avatar
'10JCW
I am perplexed how to remove this thing, specifically at the sensor that is located right before the turbo inlet. Thanks.
Old Jun 30, 2014 | 10:16 AM
Ratkiller's Avatar
Ratkiller
I had a diffcult time removing these hoses also. I don't know if they melt a little, causing it to stick or if they use some sort of adhesive at the factroy. But after looseing the hose clamp completely, ended up useing a small flat head screw driver and shoved it inbetween the hose and the pipe. I did this a 5-6 times working my way around the pipe as much as possible. Then managed to wiggle the hose off.
Old Jun 30, 2014 | 06:09 PM
'10JCW's Avatar
'10JCW
Also, the FMIC was tough to remove as well, it seems some oil pools at the cold side pipe where it connects to the IC
Kimolaoha
Jul 5, 2023 01:04 PM
KrisMiss
Jan 3, 2016 02:02 PM
Da_jesus
Aug 25, 2015 04:20 PM
minipopkart
Aug 13, 2015 05:22 AM
