JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Upgrade R56 Cooper S Clutch to JCW Clutch?
Old Jun 12, 2014 | 10:25 AM
pureinstinct93's Avatar
pureinstinct93
Hello Everyone,
I have been upgrading the parts on my 2007 Cooper S with JCW parts as they wear out or break. I have upgraded to the JCW turbo, turbo inlet pipe, and exhaust manifold so far with excellent results Now, I need to replace my clutch.
So, I have some questions:
1. Is this a straightforward parts swap?
2. I think I heard that there is a different flywheel as well for the JCW clutch. Is this true?
3. I imagine with 124,000 miles on my car I should consider upgrading the flywheel as well, even if I stick with the regular Cooper part. Does that make sense?
4. Should I/would I need to upgrade the pressure plate (I don't really know what that is) when upgrading to either clutch part?
5. Lastly, should I bother to upgrade to the JCW clutch parts at all? I am leaning towards doing so mostly because the price differences I am guessing will be a few hundred bucks or so with perhaps slightly better performance, not that I know what enhanced clutch performance would really mean.
Thanks!
Old Aug 14, 2014 | 10:46 AM
brightside's Avatar
brightside
I'm looking into this as well. I have a 2010 MCS and want to put a JCW clutch in for better durability for track days. My main question is if i need to buy a JCW dual mass flywheel or not?
Old Aug 22, 2014 | 11:30 AM
The newer R56 Cooper S clutches shares the same Part # as the newer JCW now. The clutch kit is must softer feel and most people like it. The older original clutch has a much harder feeling in the pedal and harder to push to the floor.
https://www.northamericanmotoring.co...ght-pedal.html
You can use the Cooper S flywheel. You will need a new one as you reelly cant resurface the old one/
http://www.ecstuning.com/Mini-2010-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Drivetrain/Clutch/
Options 2 go to a Clutch master Stage one Dual mass to single mass conversion. Then you have it all. Its in the link
marendt428
Nov 14, 2015 10:03 AM
marendt428
Aug 8, 2015 04:44 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
