JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW 2009 JCW engine codes help!!!!!
Old Feb 19, 2014 | 12:10 PM
Sean Sykes's Avatar
Sean Sykes
I have a 2009 factory JCW 63k with DOS CAI and DoS W2A IC running Alta Tuner stage 1 FMIC. I have only put 3 thousand miles since owning the car one year. I have had nothing but problems with the car. I had the chain assembly rebuilt due to recall and the pulley system completely replaced due to failure. I have kept all oil changes and normal maintenance done too. Recently I have been driving and the turbo boost goes in and out almost like there is no turbo and intake is silent compared to the normally working sound. I checked all hoses and clamps and everything is sealed and tightened with no visible holes or leaks. The car works again out of no where but is not consistent. My CEL came on today and read the following codes today.
P115D
P2B5B
P2D52
P2DCB
P2D9B
P2D5D
I am really trying to stay positive with this car but at this point it is extremely difficult. I am not trying to send it to the dealer again and have to once again pay thousands of dollars. Any help would be greatly appreciated. I am not a master mechanic by no means but am some what savvy with general repair and trouble shooting. Thanks in advance for any help.
Old Feb 19, 2014 | 07:06 PM
05r50's Avatar
05r50
P115D
P2B5B
P2D52
P2DCB
P2D9B
P2D5D
Maybe some of these threads will help. There seems to be a common item in the use of Alta products and DOS. But then again your talking bout intake and boost.
I don't have any of these vendors items on my car and have no opinion either way as to if they are helping or hurting you.
Good Luck.
P115D - https://www.northamericanmotoring.co...lp-please.html
P2B5B - https://www.northamericanmotoring.co...s-p2b5b-c.html
P2D52 - https://www.northamericanmotoring.co...eration-3.html
P2DCB - https://www.northamericanmotoring.co...ild-boost.html
P2D9B - https://www.northamericanmotoring.co...and-p2d50.html
P2D5D - nothing found.
Old Jul 20, 2014 | 10:57 AM
ryanschram's Avatar
ryanschram
Did you find a solution?
Sexual Chocolate
Mar 31, 2019 08:02 PM
PSIChocolate
Aug 13, 2015 12:46 PM
2manyhobbies
Aug 9, 2015 06:02 PM
marendt428
Aug 8, 2015 04:44 AM
