JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Supercharger oil check location?
Old Nov 23, 2013 | 10:14 PM
Kongfish's Avatar
Kongfish
Does anyone have a photo or diagram showing where you check the oil level for the SUPER CHARGER on a JCW 2002 model mini Cooper?
Old Nov 24, 2013 | 01:12 AM
ZippyNH's Avatar
ZippyNH
Step 1
Spend 4 hours...remove the sc...then check BOTH fill plugs...then spend about 4 hours reinstalling it...with a few new gaskets....
Not to be a smart azz...but any sc removal guide for a gen1 mini cooper s will work....
Old Nov 24, 2013 | 04:40 AM
buzzsaw's Avatar
buzzsaw
Check the DIY tab then scroll down to supercharger on the link in the signature. It may be helpful. Good luck.
Old Nov 28, 2013 | 09:01 PM
Debi's Coop S's Avatar
Debi's Coop S
Good Luck with tearing everything apart. I recommend replacing your water pump gasket while you got everything apart if you have high miles.
Old Nov 29, 2013 | 03:52 AM
daflake's Avatar
daflake
This +
Might as well replace the entire pump since you have it out. They are cheap and do fail.
Old Nov 30, 2013 | 12:49 PM
joylove's Avatar
joylove
Originally Posted by daflake
This +
+1. I just did the very same thing.
Melvinyip
Apr 17, 2020 09:28 AM
tr3y003
Oct 22, 2015 10:48 AM
Zettinger
Aug 25, 2015 04:04 PM
elightbo
Aug 17, 2015 01:50 PM
joelcseymour
Aug 7, 2015 12:43 PM
