JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Engine Differences?
Old Feb 2, 2012 | 09:04 AM
mcmmotorsports's Avatar
mcmmotorsports
Engine Differences?
Forgive the newb, but I searched and found no DOCUMENTED, DEFINATE answers both here and on teh interwebs. What, if any, are the differences between a JCW 1.6 and a S 1.6? Reading on some sites different pistons, slightly different valves, re-worked head, etc and some sites say nothing other than some remapped ECU stuff, different clutch, blah, blah, blah.
I just want some clear cut facts before I start bragging to my friends.
Old Feb 2, 2012 | 09:16 AM
czar's Avatar
czar
Regarding the engine, differences are:
Air intake box.
Different variation of the KO3 turbo, and no it's NOT a KO4.
Exhaust manifold.
Exhaust down pipe.
Pistons, 10.0:1 instead of 10.5:1 as found in the MCS
Flywheel and clutch
Maf and Map sensors,
Iridium spark plugs.
ECU tune.
If I have forgotten something, I'm sure others will chime in.
Old Feb 3, 2012 | 02:03 AM
Jack$0n's Avatar
Jack$0n
Old Feb 3, 2012 | 02:27 AM
mcmmotorsports
And here I was thinking I was gonna get smacked with a wet noodle for asking this question that has been answered 1000's of times.
Old Feb 3, 2012 | 04:03 AM
yetti96's Avatar
yetti96
It has been asked a few times but every time the answer can and do vary slightly. No harm in asking a question if you don't think it is fully answered or perfectly correct.
I have yet to see a scanned page showing the difference form a MINI publication. If I had seen one of those I would repost it.
Old Feb 3, 2012 | 08:43 AM
ronnie948's Avatar
ronnie948
Factory JCW engine is Made in Germany
If the Engine is made in Germany there must be a good reason. I have read about the Factory JCW way back in 2008 that the engine block was beefed up as well as having the transmission beefed up with different ratio gears.
What always amazed me was that they did not put anything on the engine or valve covers to say this is a JCW engine. No sticker or anything.
I have driven a cooper "S" and believe me when I say that the factory JCW is a totally different car. My JCW does have "Sport suspension" and the "S" I drove did not but as far as driving and power the JCW is top notch.
I'm not saying the JCW is better then the "S" but just much different. The JCW is for people that want excellent performance and don't really need to or want to modify their car.
I love my factory JCW but I probably will get an Automatic Transmission "S" sometime in the future and I'm sure I will love it too.
Of course I will have a dealer installed JCW performance kit installed on my Automatic "S" as well as the JCW Brakes.
If someone would just come out with a beefed up Automatic transmission that could handle the power of my JCW I would keep this car forever.
Old Feb 3, 2012 | 08:52 AM
walk0080's Avatar
walk0080
I am surprised about that also. No sticker even on the JCW intake. Cost saving I would imagine.
Old Feb 3, 2012 | 12:59 PM
bluefox280's Avatar
bluefox280
I'm willing to bet the engine block serial number would reference to such.
The Bentley publications service manual walks through the difference of the factory JCW vehicle.
- Erik
Old Feb 3, 2012 | 01:28 PM
walk0080's Avatar
walk0080
I'm sure it would, but if I go lift the hood of my car and see the serial number, I am not going to say "hey now THAT is a JCW engine because look at that serial number!"
- Erik
I have flipped through the book but will take a closer look this weekend.
Old Feb 4, 2012 | 08:43 AM
walk0080's Avatar
walk0080
From the Bentley manual...
Engine Code, type
N14 MCS - N14B16AC, VANOS
N14 JCW - N14B16TO, VANOS
Displacement cc (cid)
N14 MCS - 1598 (97.6)
N14 JCW - 1598 (97.6)
Bore x Stroke mm (in)
N14 MCS - 85.8 x 77 (3.37 x 3.03)
N14 JCW - 85.7 x 77 (3.37 x 3.03)
Comp. Ratio
N14 MCS - 10.5 : 1
N14 JCW - 10.0 : 1
Torque lb-ft @ rpm
N14 MCS - 177 @ 1600 - 5000
N14 JCW - 207 @ 1850 - 5600
Horsepower hp @ rpm
N14 MCS - 171 @ 5500
N14 JCW - 208 @ 6000
Engine Management
N14 MCS - Siemens DME MED17.2
N14 JCW - Siemens DME MED17.2
* Cylinder head gasket revised in terms of heat distribution, resulting in improved coolant flow. [EDIT: Incorrect?]
* Cylinder head wall thickness changed in some places in relation to water jacket to remove local peaks caused by increase in performance. [EDIT: Incorrect?]
* Improved intake valve seat material and extra-hardened intake-valves.
* Strenghethened piston side faces, and adapted to reduced compression ratio of 10.0.
* Charge air pipe improved to reduce pressure drop.
* Intake air filter with integrated mass air flow sensor
* Turbocharger adapted to changed conditions.
* Turbocharger and exhaust manifold materials adapted to higher exhaust gas temp (~30 Deg C higher).
* Catalytic converter two-stage design.
* Red Brembo front brake calipers with 17" wheels and 12.4" rotors.
* Appearance and acoustics, plus specific sound impedance of the exhaust system were improved to create a special sound.
Also the JCW has slightly larger rear disk rotors (and red painted calipers). And I have read the JCW has a more durable 6-speed (??).
Old Feb 4, 2012 | 08:48 AM
bluefox280's Avatar
bluefox280
Walk, see page 010-15 (Product Familiarization) in the Bentley service manual.
It walks through the mechanical changes / difference of the JCW N14.
That list is what I refered to from my previous post.
- Erik
Old Feb 4, 2012 | 08:56 AM
walk0080's Avatar
walk0080
- Erik
Yep was still typing that just now.
I notice the pic on that page shows a JCW emblem on the air filter box.
Old Feb 4, 2012 | 09:22 AM
czar's Avatar
czar
The cylinder head is exactly the same, on the MCS and JCW, regardless of what is quoted, the JCW does NOT have this: " Cylinder head wall thickness changed in some places in relation to water jacket to remove local peaks caused by increase in performance" or this "* Improved intake valve seat material and extra-hardened intake-valves" .
Old Feb 4, 2012 | 09:38 AM
walk0080's Avatar
walk0080
Where is your source of information that this is not true? Are the MINI part numbers the same? I am reading elsewhere that both items are correct - but I have no idea if their sources are also incorrect.
EDIT: And I am not trying to be difficult. I have seen several errors in the Bentley manual and it is rather annoying if there are more errors in a book that costs $100 !! A quick check of RealOEM suggests that the engine cylinder head is the same part # between MCS and JCW, but the engine block are different. Also RealOEM shows intake/exhaust valves as the same part # between MCS and JCW.
Old Feb 4, 2012 | 09:48 AM
czar's Avatar
czar
My source of accurate info, comes from my workshop, I have a few brand new MCS and JCW engines, some of which where stripped for research, modified and rebuilt, and some of which, are still untouched factory units, and besides my actual physical measured info, the part numbers are also the same between the MCS and JCW components, we are referring to here, "cylinder head and valves"
I also put up a list of differences, in this thread, post NO 2
Old Feb 4, 2012 | 09:50 AM
walk0080's Avatar
walk0080
Thanks czar - appreciate the info.
Old Feb 4, 2012 | 10:31 AM
Braminator's Avatar
Braminator
This seems high from what I read. It should be 8.3:1 for the MCS But I have read numerous articles showing it to be Comp. Ratio N14 MCS - 10.5 : 1 N14 JCW - 10.0 : 1 What gives?
Old Feb 4, 2012 | 10:50 AM
czar's Avatar
czar
What you quote as 8.3:1 is correct for the W11 supercharged 1st gen MCS, as for the N14 turbocharged MCS it has a CR of 10.5:1 and for the JCW it has a CR of 10.0:1
Braminator's Avatar
Braminator
Thx, I knew I read it somewhere.
Old Feb 6, 2012 | 06:06 PM
johnf36's Avatar
johnf36
Czar, the parts break down for the 2012 JCW n-14 shows a different fuel pump. Did they up grade the pump?
Old Feb 7, 2012 | 01:01 AM
czar's Avatar
czar
Are you referring to the difference between the HPFP on the N14 and N18 engines ?
If so, at this moment in time, I can't give a definitive answer, however I suspect, that the HPFP as fitted to the N18 engine, is simply a supersession revised HPFP, logged with a different part number, this happens quite a lot.
Old Feb 7, 2012 | 01:04 AM
johnf36's Avatar
johnf36
Nope I am seeing a different P/n for the 2012 JCW's vers the 2010 pump used on the N-14
It looks like 3 changes since 07
Old Feb 7, 2012 | 01:12 AM
johnf36's Avatar
johnf36
3 month ago the numbers showed 3 revisions now it just shows the one, I see it has been cleaned up.
Old Feb 7, 2012 | 01:15 AM
czar's Avatar
czar
I currently don't have a 2012 part number list, what I do have is the HPFP for the JCW as being: 13517588879 and for the N18 engine this: 13517592429 anything other than that, I don't know about, and will think, it will be a revised supersession HPFP, still retaining the same working pressures, the same fittings, the same drive engagement, and maybe they finally cured the pressure failing issue!
Old Feb 7, 2012 | 01:45 AM
johnf36's Avatar
johnf36
You have the same numbers I do , I should have wrote down the 2 others I had for the n-14. But you hit the nail on the head with the piston change and a possible HPFP change I am wondering the same thing. It seems to me I saw a service bulletin with this HPFP upgrade. CZAR did you find out if the new pistons were now coming from Germany or still out of France?
