JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW airbox?
Old Sep 28, 2011 | 07:58 AM
Hillis24's Avatar
Hillis24
JCW airbox?
What makes the JCW airbox so special?
Can you post up some pics of the insides and inlets?
Old Sep 28, 2011 | 09:07 AM
walk0080's Avatar
walk0080
It's special because it says JCW on it!
Real OEM might have some diagrams for you to compare. I've only seen pics like this one:
http://www.outmotoring.com/mini-coop...n2_intake.html
Old Sep 28, 2011 | 09:37 AM
00m.u037's Avatar
00m.u037
I has an expensive cone filter inside and a flap that opens at about 4500 rpm which allows more air into the engine. The flap closes when the rpm dips below 4000rpm. It stays quiet below 4500 rpm and starts to scream pretty loud afterwards. word of advise if you want to get it is do without the paper filter replace it with a foam or a cotton mesh filter. They cost way less and are both re-usable. Now the question will be which type will be better? Well you will have to read up on the older posts.
Cheers,
Old Sep 28, 2011 | 09:55 AM
Hillis24's Avatar
Hillis24
so its pretty much a flap, a hole, and a larger filter?
Old Sep 28, 2011 | 12:23 PM
TimL's Avatar
TimL
That link seems to be for the r56 intake, not the R53.
Here's a pic of the R53 JCW kit:
http://im1.shutterfly.com/media/47a1...D720/ry%3D480/
These and Dinan are said to be about tops performance-wise, but as I understand it the difference between CAIs is generally pretty marginal.
I had my sights set on a JCW intake for a while, but ended up going with the "Dave.F" modified stock airbox which tests even better than JCW (*) and is quite a bit less expensive.
(* = if anyone cares, I can try to get the exact citations from Minitorque.)
Colt45Magnus
Jul 14, 2019 06:18 PM
alistaircookie
Oct 8, 2015 10:52 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
replacement
Aug 19, 2015 08:46 AM
The_Kid
Aug 16, 2015 11:13 AM
