JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
High speed wiper problem
Old Sep 11, 2010 | 08:05 AM
0537Dave's Avatar
0537Dave
Posted this in the GP group a while ago, but reposting here to seek a larger audience of electrical troubleshooters.
What would cause the wipers to stop working in high speed mode? I realize they only go to high speed if the car is moving. When I click the lever to high speed mode the wipers freeze in place wherever they are. They work fine in intermittent and low speed, no hesitation or anything. The on-demand wipe (pushing down on the stalk) works- but only until the lever is released, and only in low speed mode. (If the car is parked, holding down the stalk does make the wipers move in low speed mode.) I believe it is supposed to function in high speed mode when it is held down while moving. Worst of all, the problem is intermittent. Most times, high speed does not work, but it very occasionally does work.
I have replaced both wiper relays in the fuse box under the hood, but the problem remains the same. Wiper stalk? BC1? Some kind of grounding problem? How can I troubleshoot this?
-Dave
Old Sep 11, 2010 | 08:13 AM
ZippyNH's Avatar
ZippyNH
Maybe the motor for the wiper has a short in it, that is only shorting due to the windings of the wires when it is activated on the high-speed mode?!
Just a guess, but if the relay is good, and the switches+grounds are good, not much more to look at.
Old Sep 11, 2010 | 05:20 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Sounds like it could even be the connector to the motor. Sometimes electrical connects can be fine under a light load and then fail when a load (deman) increases. Maybe it just needs some brass brushing to clean it up ?
Do you have a meter to check the power to the connector as well.
Old Oct 18, 2010 | 07:37 PM
0537Dave's Avatar
0537Dave
Solution
Wiper motor ground.
0537Dave's Avatar
0537Dave
Ps
Thanks for all the help!
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
Aug 12, 2015 01:24 PM
MES11
Aug 8, 2015 10:21 AM
