JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW CAI Re-Install question
Old Jun 5, 2010 | 08:12 AM
NanoBeast's Avatar
NanoBeast
Hi all,
I recently purchased an 06 MCS which has an Alta CAI installed.
I'm preparing to "un-mod" and install a JCW CAI.....without hooking up the flap function.
Not sure which electrical or vacuum hose connections are required for this install method, or if there are any unforeseen issues with other hardware?
Any advice?
Old Jun 5, 2010 | 10:50 AM
JPMM's Avatar
JPMM
there is a big how to somewhere here, it would help you much
Old Jun 5, 2010 | 02:14 PM
kazlot's Avatar
kazlot
Try the links below, they should have all the information you want.
If your not using the flap there will not be any vacuum hose or electrical connections.
http://motoringfile.com/files/JCWUPGRADE.pdf
http://www.mini-madness.com/pdf_file...structions.pdf
http://www.jwardell.com/mini/jcwintake.html
Hope this helps...
Old Jun 5, 2010 | 02:38 PM
NanoBeast's Avatar
NanoBeast
Thanks for the info.....got it installed.....much quieter than the Alta even with the "flapectomy"........think this is just the trick I was looking for.
maestro39
Oct 27, 2015 02:38 PM
David.R53
Sep 1, 2015 06:49 PM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 10, 2015 11:24 PM
papawhiskey
Aug 10, 2015 09:31 PM
