JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Opinion: When to change spark plugs?
Old Aug 16, 2009 | 02:08 PM
The QZ's Avatar
The QZ
I was just looking at getting some opinions on when to change my spark plugs. I currently have the original plugs and put 30k miles on them. I just had the jcw kit put in and was wondering when I should change them. With the kit, I'm supposed to change every other oil change, which is about 30k miles according to the obc.
Should I change them now cause they already have 30k on them? Should I wait for the second oil change which would be in another 30k?
Or should I change them in about 15k to split the difference?
What does everyone think?
Old Aug 16, 2009 | 06:39 PM
scottab36's Avatar
scottab36
I was in the same situation you were and I went ahead and changed them. It is very easy to do. The do require a 14mm 12 point deep well socket.
Old Aug 16, 2009 | 08:19 PM
The QZ's Avatar
The QZ
I think I'll go ahead and do it then. I may have some questions for you later on. It seems easy enough. Is it hard taking the wires off? Is there a torque setting for the plugs?
Old Aug 17, 2009 | 02:56 AM
scottab36's Avatar
scottab36
The coil-pack on top of the spark plug has a quick-disconnect connector that with a small screw driver will easily come off.
I did not buy the expensive spark plug socket with the rubber plug insert. I use a small piece of bubbble wrap to hold the plug in the socket.
I do not remember the torque spec. It will either be on the furum here or your MINI dealer can give it to you. I also think it was printed on the spark plug box.
Do not forget the spark plug boot grease and anti-sieze for the spark plug threads.
Old Oct 16, 2009 | 09:38 PM
ZippeeGear's Avatar
ZippeeGear
I have a really bad hesitation when I accelerate, but only when the temp outside is hotter than 70 degrees. Could it be due to my spark plugs?Does anyone have advice on this issue?
Old Oct 16, 2009 | 09:50 PM
Oxybluecoop's Avatar
Oxybluecoop
Attachment 44414
maniacalmorgan
Jan 1, 2020 11:20 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
yashmack
Aug 15, 2015 10:16 AM
