JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW tuning kit to be installed on my 2007 MCS next week
Old Sep 8, 2009 | 09:35 AM
  #26
rockridge's Avatar
rockridge
Slinger688, thanks for update. It give me a couple of approaches...
Old Sep 8, 2009 | 10:08 AM
  #27
slinger688's Avatar
slinger688
Rockridge, hope it works for you. Generally, I would say it is much better but when you are using power or at WOT, the exhaust sound will still be loud.
Old Sep 8, 2009 | 11:39 AM
  #28
tgs91
Originally Posted by slinger688
In the passenger compartment, you should do under the rear seat and in the trunk area. I used Dynamat extreme but you could use almost anything including fatmat etc, but use the good stuff, the ones with multiple different layers including something like asphalt. I did a little in the rear passenger and trunk on the sides but that is a pain with the panels to be removed.
NOTE-Be careful that you get the Dynamat or whatever brand you choose for flooring. According to the car stereo guru who just did the speaker upgrade on mine door Dynamat is different from floor Dynamat. Reason? Each are designed do deaden likely frequencies (tire/road noise from floor and wind noise from doors)
Dec 23, 2015 10:36 AM
ASRman
Aug 13, 2015 09:33 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
