JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW suspension install instructions for an R56
Old Jan 11, 2009 | 05:49 PM
Bruce/Fl's Avatar
Bruce/Fl
I have been looking for some comprehensive installation instructions or a detailed recap of a member heres experience on doing a self install of the JCW suspension. The part that I would like more info for is the part that I heard was the hardest, the front sway bar.
I'm looking for something more detaled than this 7 page pdf that I found on Motoring File.
http://motoringfile.com/files/JCW_suspension_R56.PDF
I have been trying to build my car up as much as possible, even though money's tight, by doing all the work myself. So far I did the JCW aero kit install, and painted the calipers. Now I'd like to do the suspension (Thank you Morristown MINI for the lower price, and my Dealer for matching it) the same way. But those instructions that I linked above are pretty much a parts breakdown, and that is all.
Does anybody have something more substantial?
Old Jan 11, 2009 | 07:55 PM
scott48's Avatar
scott48
yea the front bar is gonna be a real pain, its really buried in there....looks like u gotta drop the subframe, exhaust section, etc
Old Jan 11, 2009 | 09:15 PM
OasisT's Avatar
OasisT
If you have a lift, the FSB isn't too bad but you do have to drop the subframe and disconnect several things to work in/out the swaybars. If not, its going to be difficult, I have only done mine on a lift, once you figure out what needs to be disconnected, its not a bad job at all with all the right tools and a little experience.
Actually though, your Mini might handle better with the stock front swaybar(less wheelspin coming out of corners with softer front swaybar).
Old Jan 11, 2009 | 09:43 PM
Bruce/Fl's Avatar
Bruce/Fl
Thanks all, for the replies.
I do have access to a lift, at the base hobby shop, and normal tools. You mentioned the "right tools". Is there something in particular that I should be sure to have? How long did it take you? (Just curious, as I know it will take me a lot longer)
Old Jan 11, 2009 | 10:16 PM
OasisT's Avatar
OasisT
Oh, sorry on the tools comment. I just know I usually find myself running back and forth between places trying to find the tool I need. lol I think the 3rd time I made the swap, it took about an hour, but, the first time, I can't remember for sure, maybe 2 hrs? On my last swap, I think the difference was, I knew what needed to be disconnected to allow for the swap.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Mini'mon
Aug 26, 2015 01:02 PM
Minibeagle
Aug 13, 2015 10:00 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
