JCW 210 Stuttering
Subscribe
Dec 12, 2007 | 11:26 PM
My car has just had the JCW 210 kit fitted and I'm hugely happy with it - great noise and excellent performance.
However, when the car gets a bit hotter (e.g. after 100km or so) the engine begins to stutter slightly when I floor the throttle, especially between 2500 and 3000rpm.
Has anyone else experienced this and what can I do about it?
Reply 0
Dec 14, 2007 | 05:08 PM
Install one heat range colder spark plugs and make sure they are gapped correctly. Sounds like your knock sensor is retarding timing under high-load/low-rpm situations (an ideal condition for knock).
Reply 0
Dec 14, 2007 | 06:29 PM
Get a dyno tune from Jan at Revolution Mini Works and they you will be feeling a whole new side of your JCW.
Reply 0
Dec 15, 2007 | 10:00 AM
Quote: Install one heat range colder spark plugs and make sure they are gapped correctly. Sounds like your knock sensor is retarding timing under high-load/low-rpm situations (an ideal condition for knock).
If the knock sensor is retarding timing then its doing its job. It is a listening device, it will only retard timing when it "hears" audible pinging. Also the JCW kit comes with colder plugs.
Reply 0
Dec 20, 2007 | 12:56 AM
took the car into the garage and got the spark plugs changed under guarantee - car is now running perfectly.
Reply 0
Dec 20, 2007 | 03:56 PM
You're welcome.
Reply 0
Subscribe
