Interior/Exterior Underbody Neon Lighting
neon looks good, i dont know why everyone is so against it
why can some hot rods have completely tasteless neon in their engine bays while we cant have tastefully done neon under the car?
i mean, ive seen some pretty stupid looking newon on some really nice cars, ont he other hand, ive seen total POS's with a nery nice neon setup, both showing the obvious time spent (or lack therof) installing them.
Originally Posted by Ministi2005
This thread was pretty good. I'm a 43 year old guy who was actually considering some mild neon for effect just because it seems insane to do so, but I think this thread has talked me out of it.
I got a say, though, that I saw a Mini recently that had two purple lights up around the windshield washer jets on the bonnet, very small but definitely purple and facing forward - and I thought it looked great.
Maybe there is something subtle to be done with accent lighting that would be more interesting than a full blown neon glow off the bottom.
I don't mind neons at all if done properly. It's a dramatic cosmetic
change so it has to be done very carefully, very high risk to mess up...
it's like someone not knowing much about cars getting 18" wheels...
some have huge wheel gaps with the fender and some have huge
gap between the rim and rotor..but they don't see that part and
think it's hot and go out driving like that while car guys like us look
at it and say... wtf did you do to your car?!
Basically if you don't know what you're doing, don't attempt.
stock is safe.
stock is safe.
Originally Posted by kenchan
puddle lights, huh? pretty cool. Isn't that just a matter of wiring up a couple of Radioshack LED's in parallel with the foot area bulbs? should be an easy
weekend project.
might be better to wire that up to the bottom of the inside door
panels instead of under the side skirts so that it is not exposed to
weather, and will illuminate with how wide the door is opened for
better function.
weekend project.
better function.
Originally Posted by jerjer
that sounds very cool yet very darn complicated for me, is that even possible to do? it sounds pretty hard to adjust the light on how wide the door is opened.
i think my sentence was not clear on my post. what I meant was that
since the illumination is from the door, you should get better functional
illumination instead of just illuminating below the skirts.
you would have to put a variable detection switch if you want to
intensify the illumiation as the door opens wider...which can be done
but not sure if it's worth it.
Ok. I gotta come back at this again.
Somewhere on this site I saw a graphic of a flashing red light going back and forth INSIDE the hood scoop. I thought that was pretty insane.
Has anyone seen that graphic and could they direct me to it?
i'm working on glowing the scoop area now, i need to mill a piece of clear plastic to put inside the top of the scoop so is spreads light evenley with only 2 LED's. if you expose the LED's, you see them in the reflection on the scoop and it looks funny....
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Aug 19, 2015 12:51 PM
