Interior/Exterior HELP...Removing and replacing lower grill piece
Old Mar 26, 2007 | 05:25 AM
maginter's Avatar
maginter
Hi All -
OK, befor I bust my stock grill piece to replace it with a chrome one, what is the best way to remove the lower grill piece?
TIA,
Mark
Old Mar 26, 2007 | 05:44 AM
Johnna's Avatar
Johnna
Originally Posted by maginter
Hi All -
TIA,
Mark
There may be an easier way ...... I ended up removing the bumper cover and doing it that way. Good luck!
Old Mar 26, 2007 | 07:54 AM
BlimeyCabrio's Avatar
BlimeyCabrio
I think that's your only option - the grille is fastened in from the rear of the bumper cover quite well...
Old Mar 26, 2007 | 10:45 AM
maginter's Avatar
maginter
So what is the best way to remove the bumper cover. Is the a procedure on line that someone has put together, or am I just thinking to hard??
Old Mar 26, 2007 | 11:31 AM
kapps's Avatar
kapps
It's in the Bentley manual. You remove the screws under the bumper (I think there's 3), remove the two inside the fender liner (these are used to align the cover when you put it back on), and there are a couple on the top side that you can see with the bonnet up. Once those are removed, the cover should come out pretty easy. Make sure you disconnect the power to the parking lights before you pull it all the way off.
Old Mar 26, 2007 | 12:45 PM
maginter's Avatar
maginter
Thanks....That helps..
blackie
Jan 18, 2017 09:56 PM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
