Interior/Exterior Remove trim piece under steering wheel
Old Feb 17, 2007 | 09:34 AM
mikeesmini's Avatar
mikeesmini
I am trying to find out how to remove the trim piece under the steering wheel so I can get at the down tube screws on the driver side. I need to remove the upper screw which will allow removal of down tubes exposing the stereo. I am in the process of installing a Dice interface for my iPod.
Does anyone ot there know how to do this?
Old Feb 17, 2007 | 09:47 AM
ChrisW's Avatar
ChrisW
Pull down really hard and it will pop out.
Old Feb 17, 2007 | 09:48 AM
Speedee's Avatar
Speedee
The bottom piece under the steering wheel is hinged at the bottom. Simply pry it with a butter knife or something similar at the top outer and inner areas, and it will swing down, out of the way. If you need to remove it totally, it will seperate at the hinges as well...
Old Feb 17, 2007 | 04:08 PM
mikeesmini's Avatar
mikeesmini
Many thanks to chrisW and speedee for your quick response and great advice. It worked as you both stated.
Old May 22, 2011 | 04:44 PM
WJHMH's Avatar
WJHMH
I'm wondering the same thing, not wanting to remove the airbag though.
Old May 22, 2011 | 06:16 PM
rkw's Avatar
rkw
There's no airbag down there. The procedures described here have nothing to do with an airbag.
Old May 22, 2011 | 06:25 PM
ZippyNH's Avatar
ZippyNH
Second the procedure, and no airbag...
this part is removed to put in the euro parcel shelf....and replaced with the mini oem euro part....a good hard yank...and it pops off.
sevin
May 2, 2026 06:11 AM
Getrieben
Sep 12, 2024 07:03 AM
kazyn
Oct 25, 2019 02:34 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
