Interior/Exterior M7 Front Grills
Old Feb 13, 2007 | 08:19 PM
AstroBlackS's Avatar
AstroBlackS
M7 Front Grills
OK, maybe I'm not good with searches but I tried and did not fond the info I was looking for...
Has anyone installed the M7 upper/middle grills or the ultimate front grill? I just wanted to know how they install because I'm thinking of getting them.
Old Feb 13, 2007 | 08:24 PM
SRTech's Avatar
SRTech
The upper grille installs with two screws with nuts and is the easiest. It is best to remove the bumper for the middle and lower grilles. The middle grille may or may not require you to drill a hole depending if you have an arrow bumper or not. The lower grille requires three holes to be drilled. It's pretty easy, just line up the grille and hold in place to mark where the holes go, then drill and then install the clips and screws.
Steve
Old Feb 13, 2007 | 09:02 PM
1nf3rn0's Avatar
1nf3rn0
Easy as pie. You will probably want to paint the underling metal black to match though...
Old Feb 14, 2007 | 06:33 AM
kapps's Avatar
kapps
Here's the link to when I installed the lower grill.
boostedhaze
Jan 2, 2018 07:26 PM
wkp1219
Nov 13, 2015 07:52 AM
dcrna1
Aug 19, 2015 01:30 PM
FLYM1N1
Aug 15, 2015 11:20 AM
