Interior/Exterior Removing the navigation
Old Jan 31, 2007 | 05:49 PM
ANT818's Avatar
ANT818
can't stand the navigation system anymore.
anybody covert the navi back to speedometer???
i need help
Old Jan 31, 2007 | 06:09 PM
Murmini's Avatar
Murmini
I think it would be very complex to do this as the wiring harness is probably different. Also, the speedometer or instrument cluster, as it is called, is the primary interface and connectivity point between the K-bus, CAN bus and the two diagnostic buses that carry most of the car's data feeds.
Old Jan 31, 2007 | 06:15 PM
4GAZM's Avatar
4GAZM
im in conneticut want to drive down and well tear the car apart and swap my speedo for your nav hehhehe
the car was built with plug and play in mind so if you have to change the harnesses it should alll work out, it just matters what you consider difficult
Old Jan 31, 2007 | 10:15 PM
JPMM's Avatar
JPMM
Hi, I,m making an aquarium out of ours, kind of like what the beatniks did with old TV's .
Old Jan 31, 2007 | 11:24 PM
Eric_Rowland's Avatar
Eric_Rowland
i need help
Details? What can't you stand?
There are definitely people who want to switch from speedo to Nav, but there's quite a bit of wiring harness work.
What's your configuration? Maybe someone would want to swap...
Old Feb 1, 2007 | 05:18 AM
BFG9000's Avatar
BFG9000
Maybe just leave the screen in the dash and use it to play DVDs and Playstation/Xbox? Some here have done it (sadly there's not enough room in the car to flail a Wii controller around without injury).
A rearview camera would be possible too with a setup like that.
Bank999
Navigation/Audio
Aug 30, 2015 08:51 PM
kyungmanpark
Aug 23, 2015 07:26 PM
greekzilla
Aug 23, 2015 03:44 PM
