Interior/Exterior Ultimate Pedals.... pedals!
Old Jan 25, 2007 | 07:25 PM
kyriian's Avatar
kyriian
after 3 years wait, i finally have aluminum pedals!
before everyone ask why there are round head phillips screws in there, its because i was promised flat head ones, but got the rounded ones.... sigh
and the fact that i had to choose which drilled hole i had to use to get the screw through... i tried to make it as nice as possible, but there are ALOT of limitations to where you can drill into the pedals... the clutch for example, drilling it down is no problem, but finding enough space behind it was... i drilled a hole on the side, but the pedal arm was so thick i cannot get a washer in there, same as the top, i wound up drilling 2 holes at the bottom to secure them.... and was forced to do the same on the brakes...
nonetheless... they look good though, finish is top notch, and both brake and clutch pedals actually conform to the shape of the stock mini pedals
nice mod to do on older cars, or coopers who dont want factory pedals
Old Jan 25, 2007 | 08:09 PM
kenchan's Avatar
kenchan
nice! now you need new floormats.
Old Jan 26, 2007 | 05:40 AM
kyriian's Avatar
kyriian
i do.... but im afraid they look even worse than the no-floormat floor...
it is winter over here... unfortunately
PelicanParts.com
May 14, 2026 04:59 AM
drrigg
May 27, 2022 03:31 AM
scfiveo
Sep 27, 2019 02:27 PM
OutMotoring
Mar 3, 2017 06:29 AM
PelicanParts.com
Accessory Products
Oct 1, 2015 01:23 PM
