Interior/Exterior Door Mod: LED Puddle Lights and Map Compartment Light
Old Feb 4, 2007 | 09:14 AM
  #51
Yo'sDad's Avatar
Yo'sDad
Here is a strip of pics that should be self explanatory as to all of the steps to install the oznium strip of 24 LEDs in the puddle light location.
YD
Old Feb 4, 2007 | 09:49 AM
  #52
PuppetMaster2u's Avatar
PuppetMaster2u
THAT is a fantastic write up
Old Feb 4, 2007 | 10:03 AM
  #53
rkw's Avatar
rkw
Yo's Dad, excellent write-up and photos, and very professional job!
I'd like to mention that if you don't mind losing a few LEDs, you can shorten the strip to fit completely between the door panel fasteners. Oznium told me that you can cut them off the end in groups of 3.
Old Feb 4, 2007 | 10:05 AM
  #54
irieman's Avatar
irieman
This thread gets extra points for excellent write-ups and pictoral walk-throughs! Of course, "drill a hole in your MINI" is soooo not in my vocabulary! but it does give me some ideas!
:i:
Old Feb 4, 2007 | 10:17 AM
  #55
Yo'sDad's Avatar
Yo'sDad
I wish I had known at the time that I could clip off three LEDs, but I did this before I learned that info. That would have eliminated doing the extra trim work around the panel to door connector.
YD
Old Feb 4, 2007 | 10:24 AM
  #56
Vinyl Styles's Avatar
Vinyl Styles
I'd love to do this to my 04 - but the 04's aren't wired up with a stock puddle light. Any idea on what to tap into??
Old Feb 4, 2007 | 10:34 AM
  #57
Yo'sDad's Avatar
Yo'sDad
A wiring diagram would be nice. Just tap into the wires that light your footwell lights.. They will come on and go off already at the right times.
The hard part will be running a wire from the cabin through the rubber tunnel and into the door. The tunnel is there, so just fish another pair of wires through it (I know, easier said than done).
YD
Old Feb 4, 2007 | 10:48 AM
  #58
MNEEME's Avatar
MNEEME
YD
There's a "Connector" blocking your way. Where the rubber boot meets the cabin.
See the "connector" Much easier said then done. I still haven't got to mine yet. And if you want to run wires people say you can drill through the "connector" Thats what some have done for upgraded speaker wires.
Old Feb 4, 2007 | 10:57 AM
  #59
rkw's Avatar
rkw
Originally Posted by ijcwmc40
I plan to do the same mod but with one Oznium's SuperFlux 4Chip LED's.
If you do that, I'd suggest positioning it inwards towards the door hinge, and also continue to use the stock puddle light but replace the bulb with these from v-leds: http://cgi.ebay.com/ebaymotors/2-V-L...9047QQtcZphoto. I wrote about the v-leds bulb in this thread (see posts from #197 to 207).
Old Feb 10, 2007 | 06:26 PM
  #60
ijcwmc40's Avatar
ijcwmc40
RKW -
I don't have OEM puddle lights ('04) so I'll test what position looks the best before I go drilling holes - I was thinking near the center would be a good spot.
Old Feb 11, 2007 | 03:55 PM
  #61
Yo'sDad's Avatar
Yo'sDad
Looking at the connector picture, it looks to me like a space in the near corner near the shiney rivit to shake a wire.
Again, I'm just going by the pic...
YD
Old Feb 11, 2007 | 04:03 PM
  #62
MNEEME's Avatar
MNEEME
YD
Maybe I have to look again. I think theres a "connector" in the rubber boot too.... So you gotta get past that first... I'll look again
Old Mar 20, 2007 | 09:23 PM
  #63
PredMini's Avatar
PredMini
I finally got the 9.5" strips zip tied to the bottom of the seats. I haven't run the wiring yet, I'm clipped to the puddle light on the passenger door for the pic. I just used 2 zip ties to connect oznium's LED strips to the metal bars under the seat bottom front and back. The front wasn't that hard, but the back was a pain. I ended up cutting the hook part off a clothes hanger, squishing it a bit and taping the zip tie to it in order to fish the zip tie over the bar in the back. It's tight and the seat cushion rests on the bar.
Footwell and Puddle Lights - Stock lens with 90 deg blue LEDS
Door Panel - 2 orange superflux LEDS
Seat bottom 1 blue 9.5" LED strip front and 1 blue 9.5" LED strip rear
The lights appear brighter in this pic than in person, but they still look great. I don't think I'd go any brighter.
Old Mar 20, 2007 | 11:39 PM
  #64
ImagoX's Avatar
ImagoX
Looks GREAT, Pred!!
Wiring and zip-tying stuff under the seat IS a pain... And MY lights are cathodes, so I had to attach rigid bars AND a transformer on each side... If I had it to do over, I'd simply unbolt the seat and do it out of the car - that way I could zip tie and attach wires in comfort AND run the power leads quite easily. Ah well - live and learn, right?
Old Mar 21, 2007 | 12:55 AM
  #65
rkw's Avatar
rkw
The wiring is a pain to do properly. I did take my seats out, along with the long trim piece that makes up the inner door sill and kick panel. Then I was able to run the wires alongside the existing wiring harnesses, completely hidden and protected. You can save a lot of work if you are satisfied to tuck wires behind the edges of the trim panels.
I'm not sure I follow why you found it difficult to attach the LED strips under the seats. Here's a picture of the LED strip under my passenger front seat that lights up the rear footwell. The bar I attached it to is easy to access.
Old Mar 21, 2007 | 06:42 AM
  #66
PredMini's Avatar
PredMini
The front one was a snap. I've got one on the same bar pointed toward the front. The rear one was a pain. There is a bar back there, but it's tucked up against the seat pad. It's also close to the rear cover which makes getting a zip tie around it a pain. It would probably have been much easier to pull the seat instead of trying to fish them.
Old Mar 21, 2007 | 06:56 AM
  #67
ImagoX's Avatar
ImagoX
See, *I* attached the cathode tubes to the plastic seat back sheild and not that bar. I did this because cathode bars are breakable (unlike LED strips) and I was worried that my teen's boat0like sneakers might FUBAR them. I also wanted the glow to only show when the seat back is pulled forward, which this installation accomplishes. I did NOT pull out my seats, so cramming my hand under there to pull tight the zip ties was a bit of a chore.
That said... I used cathodes because they were all that were available (Oznium released the LED strips a few months after I did the MOD) and I plan to replace them this suummer with strips. Honestly, I WOULD have already (I have to use a relay to drive the cathodes off the diming cabin lighting due to technical reasons) but the blue light from the cathodes is cooler and less green than the LED light, and I like the color.
Old Mar 21, 2007 | 07:38 AM
  #68
Drillslinger's Avatar
Drillslinger
Do the LED strips (as pictured above) come with or require resistors?
Looks great! I'm 90% sure that I'll do something similar myself
Old Mar 21, 2007 | 08:24 AM
  #69
ImagoX's Avatar
ImagoX
All resistors are pre-wired and sealed inside silicone - these will work even underwater!
Just hook them to a 12V power supply (remember to use a fuse unless you tap into the cabin wiring like I did -it's all fused already) and you're good to go! LEDs will handle being "dimmed" just like an incandescent bulb (unlike cathodes) so you don't have to worry about that either.
Old Mar 21, 2007 | 09:13 AM
  #70
Drillslinger
Since I'm too lazy to search () how close do the Oznium Orange strips compare to oem?? (Sounds like a Post-glowin on the Dragon project )
Old Mar 21, 2007 | 09:43 AM
  #71
PredMini's Avatar
PredMini
I don't have the strips in orange, but there are 2 of the orange superflux LEDs in door pockets of my pic. They match very well with the stock lighting. If the strips are the same I'd say pretty well dead on. I'm only 50 min north of you if you wanted to get together or had questions about an install.
I think the Nashville group is going to get together sometime before the Dragon for a mod party. I'm not sure if you've been or I have met you, but some of the Huntsville/Birmingham BAMA Mini guys have been up to mod with us. We'll probably meet at Monk's place just off the Spring Hill exit on 65. Probably about an hour or so from HuntsVegas if you're interested.
I think I'll be doing at least 1 LED boot mod at the next meet.
Oh, and the dimming is way cool!
Old Mar 21, 2007 | 10:17 AM
  #72
ImagoX's Avatar
ImagoX
Remember as well that LEDS and strips can be "tinted" using Sharpie markers iif the color needs to be adjusted. I ordered some individual orange LEDs for my switch box, for example, that turned out to be more yellow than the MINI OEM lighting. I put about 7 coats of red Sharpie on the LEDs until the color had deepened to an exact match. The "red" LEDS you see here actually started out as clear w/ an orange diode, then I ground off the tips (makes for a more "soft, glowing" effect) and hit 'em with my Sharpie. You can also do things like add blue or purple Sharpie to red LED strips for some truly custom colors.
Old Mar 21, 2007 | 12:45 PM
  #73
Drillslinger
OK, here's a wiring question... how would I wire a LED strip into the footwell to be lit while the headlights are on, but turn off when the door opens? I like the std footwell light when the door's open cause that's when you want visibility, but when the door's closed it would be cool if the LED strip was on
Am I making any sense? I haven't had any coffee for 15 minutes or so :impatient
Old Mar 21, 2007 | 01:14 PM
  #74
ImagoX's Avatar
ImagoX
Hmmm... Well you could use a relay, triggered by the positive current in the parking lights to turn the LEDs on... See this diagram for details:
http://www.oznium.com/forum/topic10892
Turning them OFF with the door open, though? Hmmm... How about using a momentary switch, placed inside the door (so the switch pops OFF when the door opens and is depressed ON when it closes) to interrupt the current? Your circuit then would be:
Power (turn signal lights) -> Relay -> Momentary Switch in door -> LEDs.
Old Mar 21, 2007 | 01:25 PM
  #75
PredMini's Avatar
PredMini
What he said!
I don't know that I wouldn't install a temporar switch to get an idea of how they work when driving @ night or just grap a 12v battery and test away.
What color are you going with? I don't know that I'd want my blue strips on when I'm driving. Might cause too much eye strain.
I don't know why the drivers side rear was such a pain form me. I had the passenger side front and back done in less than 15 min at lunch today.
Now for the wiring! I wish my EAS trim tools were in already. They look like they will be handy for the wiring run. I've also got a Dice iPod adapter installed. Its wiring is running up the passenger side and needs to be tucked away as well.
