Interior/Exterior best paint to use?
Old Nov 13, 2006 | 03:51 PM
Jtrem's Avatar
Jtrem
best paint to use?
Ok so i have a few days off this week and have decided to paint my dash. what type of paint should I use and which would work the best?
thanks
Old Nov 13, 2006 | 04:17 PM
qwertmonkey's Avatar
qwertmonkey
Luckaly, I just did this about 2 months ago! I went to lowes and picked up some spray enamel specifically for plastic. I also picked up spray primer and spray clear. After the whole thing was said and done, it turned out pretty well.
I don't think the brand matters. Just make sure you use the same brand for all of your materials.
Good luck!!!
Old Nov 13, 2006 | 04:20 PM
NMgokart's Avatar
NMgokart
If you can find the right color, Krylon Fusion for plastic would work well.
If not, you'll be visiting a body shop for the correct color.
Old Nov 13, 2006 | 04:21 PM
SHRTSTAK's Avatar
SHRTSTAK
http://www.paintscratch.com/
You can get factory color match paint in different quantities. Make sure you give it a decent sanding and use an adhesion promoter designed for plastic if you want it to last.
Old Nov 13, 2006 | 04:28 PM
qwertmonkey
Thats the brand I used.
Old Nov 13, 2006 | 04:42 PM
jeffc's Avatar
jeffc
7th Gear
Qwert do you have any pictures?
Old Nov 13, 2006 | 07:40 PM
polizei's Avatar
polizei
You can see Qwert's threads here:
https://www.northamericanmotoring.co...ad.php?t=78809
https://www.northamericanmotoring.co...ad.php?t=70174
-Cody
Old Nov 14, 2006 | 03:01 PM
Jtrem's Avatar
Jtrem
can i use that plastic hobby paint or no?
Old Nov 14, 2006 | 03:11 PM
skitelluride531's Avatar
skitelluride531
Save yourself the money and send it to a body shop. I tried to do it myself, and it didn't turn out too well. For some reason I was never able to reproduce the glossy look that paint should have.
Here is my interior after I sent the panels to a paint and body shop.
And in case you were wondering what it looked like when I TRIED to do it myself:
Old Nov 17, 2006 | 05:00 PM
Jtrem's Avatar
Jtrem
ok well i started the process tonight. lets see how it will turn out im doing it piece by piece to make sure its going to come out alright. I have the primer on right now. Im using rust-oleum plastic primer. Im also using house of kolor paint. I have a pro. spray gun and a small sudio so i will be able to do all the work in there. Im pretty sure i wont have any trouble re-creating the glossy look. Ill post pictures tomorrow of the finished A/C Rings.
Old Nov 17, 2006 | 08:05 PM
Jtrem's Avatar
Jtrem
ok so far for my test pieces i have 1) sanded them 2) used a paint thinner to clean them 3) sprayed the primer coat 4) used a heat gun to dry them 5) now sprayed the top coat. The top coat will dry overnight and in the morning I will color sand and then shoot the clear.
Old Nov 17, 2006 | 08:18 PM
skitelluride531
You need a lot more than just one coat of paint. The best way is to do several very thin layers with wetsanding in between each.
Old Nov 17, 2006 | 08:36 PM
Jtrem's Avatar
Jtrem
i think ill be good with the paint im using. I used this paint for my body panels on my '02 and it turned out great. We shall see.
bahman
Feb 14, 2016 10:29 AM
jeri534
Nov 6, 2015 01:40 PM
vulkandino
Oct 31, 2015 08:29 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
M7Speed
Oct 1, 2015 07:05 AM
