Interior/Exterior Scratched door handle fix.
Old Nov 3, 2006 | 11:50 PM
AlpinaM3's Avatar
AlpinaM3
Is your door handle scratched? Especially the vertical one that goes up at a slight angle. Mine was getting worked over with ring and watch scratches probably from the wife. I ride a road bicycle and we wrap the handle bars with bar tape so I got to thinking.
I found some that is black, no logo and no glue or sticky back made by SPECIALIZED BICYCLE. It is super stretchy and I started from the bottom, went up overlapping about 3/4 of each pass. When you start you have to overlap the end and pull tight to get the stretch of the tape to hold the tape it overlaps. At the top I electrical taped it to hold in place then went over it with the supplied finish tape that was supplied. It actually looks pretty good. I did not want to paint it and I could always go buy one if I messed it up. It’s a 14 buck fix and the black matches the door panel just fine. One box of two roles will cover 4 sections of vertical handle. Cut one role in half for two doors. Sorry no pics.
[FONT=Times New Roman][SIZE=3] [/SIZE][/FONT]
Old Nov 29, 2006 | 01:50 PM
///MINI's Avatar
///MINI
Wow, I just saw this message and am about to do the same thing. Do you have any pics of the end result?
Thanks.
Old Nov 29, 2006 | 03:30 PM
trico's Avatar
trico
Been done before. Check out this post and the Lizard skins -
https://www.northamericanmotoring.co...oor#post108408
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Filmy
Sep 7, 2015 08:27 PM
Southern Marylander
Sep 3, 2015 05:46 AM
Ntety
Sep 2, 2015 08:39 PM
spackletooms
Sep 1, 2015 10:12 PM
