Interior/Exterior How and how hard is it to remove dash?
Old Nov 3, 2006 | 10:28 PM
MarioKart's Avatar
MarioKart
Vendor
My dash creaks alot and I would like to remove it and Dynamat the bottom of it, much like I have done to most of my car. Does anyone know how many screws I need to remove? Anything will help
M
Old Nov 3, 2006 | 10:35 PM
Tüls's Avatar
Tüls
Turbius Maximus
it's easy mang... come by the shop one weekend while I am here... I'll be glad to show ya
Old Nov 4, 2006 | 08:24 AM
DixonL2's Avatar
DixonL2
HEY - wait a minute! What about us folks who aren't near the shop? Brief description???
Old Nov 4, 2006 | 09:01 AM
napptym's Avatar
napptym
Tuls,
I'm new here.
Where is your shop?
I'm in the Sherman Oaks area.
Old Nov 4, 2006 | 03:30 PM
ProfessorDave's Avatar
ProfessorDave
I'm pretty sure I've seen some threads on this. There are also threads on how to solve the dash rattle. I thought mine would have to be removed for this, but the dealer just put some thin strips of insulation along the dash where it meets the windshield. Works great!
Old Nov 4, 2006 | 04:26 PM
sukgar's Avatar
sukgar
Over all, it's not too difficult. There was a slight problem with removing the panel under the steering wheel. I highly recommend the Mini Cooper service manual 2002-2004. You can get them on ebay or amazon.
Old Nov 4, 2006 | 07:22 PM
Dr Obnxs's Avatar
Dr Obnxs
To remove pad...
remove the two plastic panals covering the end of the pad, one each side.
There are two screws on each end. Remove them. Lower the steering wheel to get a bit more access, and move the pad forward and up. Out it comes! I just removed mine (again) and used contact cement to cover the top of the plastic dash under the cover with felt.
Matt
Old Nov 4, 2006 | 08:32 PM
Tüls's Avatar
Tüls
Turbius Maximus
Thanks Doc... sorry guys... just so tired workin these days... being a writer is a stretch sometimes... I'll see what I can do.... how's this?
here's link!
Motoring File... DIY:
How to Remove the Dashboard Cover
Old Nov 5, 2006 | 05:06 PM
MarioKart's Avatar
MarioKart
Vendor
here's link!
I revmoved it and it was way too easy. I didn't even remove the tach torx bolts. I Dynamated the underneath of the dash, it cut down some of the creaks but there are still litte critters makings sound closer to the window.
Also Tuls, can you call me tomorrow. I need to talk to you about bring in the car this week.
M
Old Feb 7, 2007 | 02:23 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
OK, I tried this last weekend on an '05 MSC, and it didn't work! There were 4 large Torx bolts inside the defroster vents on the dash pad, so I removed the 4 side bolts as per instructions, and the 4 larger bolts in the dash vent, but still that sucker was attached to *something* darn it.
Any hints much appreciated thanks,
Old Feb 7, 2007 | 03:40 PM
rkw's Avatar
rkw
You have to really want to do it. See post #13 in this thread: https://www.northamericanmotoring.co...ad.php?t=58517
Old Feb 7, 2007 | 05:06 PM
ImagoX's Avatar
ImagoX
DEPENDS ON THE YEAR!!
If it's a 02-04 (2-peice dash), then only 4 torx screws...
If it's a 05-06, then you have to remove the glove box, BOTH A-pillars, all 3 peices of the dash trim and like 8 screws... Also, the A-pillars have tabs that, if damaged in the removal, CANNOT BE RE-ORDERED separate from an entire new pillar assembly (so be very, very careful!).
In other words, it's a LOT more work to remove the later models' dash.
That's because on the '05 and '06 the A-pillars hold the dash, as well as several screws that are hidden behind the painted trim panels. I had this exact same issue trying to do my speedo gauge face replacment. Luckily, you don't have to pul out the dash for THAT project, but you certainly do for this one, I'm afraid...
Old Feb 7, 2007 | 06:20 PM
UKSUV's Avatar
UKSUV
M
That adds weight and you dont want to add any more.
Old Feb 8, 2007 | 10:08 AM
DrPhilGandini
Thanks ImagoX! I felt there was more to it, and your description fits my experience very well. And the A-pillars are a beartch, having had the Dealership do them once already. I think I'll live with the rattles and creaks...it's good for building character, and I need that anyway.
cheers,
triple5soul
Nov 19, 2019 07:46 AM
eatsleepautox
Oct 30, 2015 06:46 AM
greekzilla
Aug 23, 2015 03:44 PM
StuRat
Aug 20, 2015 07:17 AM
