Interior/Exterior Anyone have the HomeDepot part# for rear wiper delete?
Old Oct 29, 2006 | 09:50 PM
MarioKart's Avatar
MarioKart
Vendor
I want to remove my rear wiper but I need a plug for the glass. Does anyone know the exact piece I will need?
Thank you
Mario
Old Oct 29, 2006 | 10:11 PM
Tüls's Avatar
Tüls
Turbius Maximus
go to ace hardware...they have what you need... iforget which plug but its plastic... it clips in...i added some silly cone to insure no leakage...
Old Oct 29, 2006 | 10:14 PM
spillman's Avatar
spillman
The end of a factory plug wire fits perfectly. Just fill the inside with silicone and a little around the outside.
Old Oct 30, 2006 | 08:18 AM
MarioKart's Avatar
MarioKart
Vendor
This found on the car now? Do you have any pix to help me out? Also what do I do with the water tube that feed the rear sprayer?
M
Old Oct 30, 2006 | 08:24 AM
spillman's Avatar
spillman
M
I was refering to the end of the factory spark plug wire. If you have one laying around cut the end off. Then fill the inside with some black silicone, smooth the end, then apply a little to the outside. Slide it in the hole and let it dry.
Old Oct 30, 2006 | 08:59 PM
Fatherdeth's Avatar
Fatherdeth
Go to Lowes, then go to the hardware section. There will be drawers in there with different automotive clips and stuff. Find the one with the blanking plugs and get a 1" (1 inch). Remove wiper motor and arm. Surround the back of the plug with silicone and insert. Done.
Old Oct 30, 2006 | 09:09 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
1 1/8" from Lowes is perfect.
cheers,
Old Oct 31, 2006 | 11:33 AM
jyung's Avatar
jyung
Speaking of, what have folks done with the rear washer to prevent accidental spraying inside the boot? - is there something quick yet more elegant than a golf tee/screw to plug things up?
Old Oct 31, 2006 | 11:56 AM
kenchan's Avatar
kenchan
excellent description!!!
Old Oct 31, 2006 | 12:03 PM
Yucca Patrol's Avatar
Yucca Patrol
How about re-routing the hose as an intercooler sprayer?
Old Oct 31, 2006 | 12:05 PM
fred3's Avatar
fred3
How will you keep the rear window clear?
Old Oct 31, 2006 | 12:56 PM
AZMCS's Avatar
AZMCS
Side mirrors, my friend, are your friend after this mod.
Old Oct 31, 2006 | 01:09 PM
herbie hind's Avatar
herbie hind
why is this being done ? just for looks? any pics?
Old Oct 31, 2006 | 01:43 PM
spillman's Avatar
spillman
Weight reduction was my reasoning... The window doesn't get all that dirty...
Old Oct 31, 2006 | 02:00 PM
Bahamabart's Avatar
Bahamabart
I forget who it was that did this delete but they also mounted the "pisser" in the hole aiming straight back. Whenever anyone would tailgate, well you know what would happen
Old Oct 31, 2006 | 05:43 PM
herbie hind
now that's too funny!!
Old Nov 1, 2006 | 09:19 PM
Fatherdeth's Avatar
Fatherdeth
I just capped my line off with a vacuum hose cap. I don't recall what size, but I have a surplus of different sizes. The cap went on real tight, but for insurance, I put a zip tie around it also. Now I'm just careful not to hit the switch for the rear wiper.
My reasoning for the removal was for several reasons. One was because the wiper is pretty worthless and it acts as a shelf for dust. I also went for a little weight reduction, and my last reasoning was for a clean look. I don't drive mine every day, so I'm not worried about having a functioning wiper.
Old Nov 2, 2006 | 06:37 PM
Mahatma Kane's Avatar
Mahatma Kane
I think this is a great idea to delete the rear wiper. I have always thought they were a useless, cutesy appendage. Have you ever wondered why they are considered to be a necessity on a hatchback ( "but how will you clear the rear window?') but no one expects them to be on a sedan, which also happens to have rear glass.
Old Nov 2, 2006 | 06:56 PM
claancy's Avatar
claancy
Maybe because the shape of hatchbacks (and vans, and station wagons and SUVs) mean that they collect a ton more filth on the rear glass than a sedan? Airflow moving over the back glass on a sedan keeps it relatively filth-free. However, the aerodynamics of hatchbacks and the other above-mentioned vehicles create a low-pressure area where the back end abruptly drops away (rather than sloping down as on a sedan). This is what causes the infamous "dirty bum syndrome."
Ever notice the rear spoiler on some SUVs (The 80's-style Chevy S10 Blazer comes to mind)? They direct the air moving over the roof down and across the back glass, and work quite well at keeping the rear glass clean without using a rear wiper.
Old Nov 2, 2006 | 08:27 PM
Longboard Mini's Avatar
Longboard Mini
I'm doing this this weekend and I'm adding the pee hole. You have to love the pee hole.
Mario, you keep influencing me. I have Dynamat on order.
Longboard
Old Nov 30, 2006 | 03:08 PM
Jtrem's Avatar
Jtrem
so is it the 1 1/8 plug or the 1" ?
Old Nov 30, 2006 | 03:56 PM
MarioKart's Avatar
MarioKart
Vendor
1" worked well for me, I think 11//" might be too big. make sure you plug the hose for the rear sprayer. you don't want it leaking everywhere.
Mario
Old Nov 30, 2006 | 08:14 PM
johnnymg's Avatar
johnnymg
That's BRILLIANT!!!! .
Question: Is there a separate fluid supply for the rear window sprayer? If so.................... a lightweight oil would be perfect for a rear pointing spray.
Old Nov 30, 2006 | 08:45 PM
MarioKart's Avatar
MarioKart
Vendor
No, sprayer is built into the wiper. Do you want to make your car like that video game Spy Hunter?
Old Jan 21, 2007 | 05:09 PM
KiLO's Avatar
KiLO
So, I'm doing this tomorrow... Any tips on hooking up the tube to make a "pisser" as you guys have called it? At first I thought I wanted to plug it up, but I think that sounds more fun!
I will probably go to Pep Boys first thing in the morning to see if I can just pick up a sprayer end.
