Interior/Exterior Spray Paint Part Number?
Old Sep 18, 2006 | 09:26 AM
Mr. Pep'r's Avatar
Mr. Pep'r
Does anyone know if Mini sells spray paint that color matches the interior colors? I know Ford does....but this is no means a Ford.
I am looking for the gray that is around the steering column.
Thanks for your help.
Old Sep 18, 2006 | 01:50 PM
sccooper's Avatar
sccooper
I've been considering this too for my brake calipers.
You might try your local automotive paint supply, I hear they can do it at some of them. I was in there the other day and they have all of the books with the manufacturer's color codes, they had MINI in there too under BMW, and they can mix you some touch up paint based off of your paint code too. I was getting a touch up bottle for my Audi A6. I know MINI sells touch up paint because I got that but it was a two part base coat and clear coat in bottles with brushes, not sure about the spray.
Old Sep 18, 2006 | 02:19 PM
ImagoX's Avatar
ImagoX
Anything you use on brake calipers, sccooper, will have to be special High-Temp paint or it will peel almost immediately. I'm sure you already knew that, but just an FYI for anyone else...
Old Sep 18, 2006 | 03:14 PM
Mr. Pep'r's Avatar
Mr. Pep'r
Thanks sccooper for the reply.
I know that Ford sells color matched spray paint for their interiors and I am hoping BMW/Mini does also. I am going to call the dealership tomorrow.
If worse comes to worse I can get it painted at a local body shop. I am looking for the factory look and thinking a brush will not yield the results.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
absolutcamper
Aug 24, 2015 12:27 PM
jr_R52
Aug 21, 2015 01:45 PM
xraycat
Aug 15, 2015 06:43 AM
