Interior/Exterior After Market shift knob question.
Old Apr 3, 2003 | 01:59 PM
Black-n-blue-MCS's Avatar
Black-n-blue-MCS
I'm thinking about an after market **** for my S (delivery of my MINI in a month or so). From other threads I've found out that the **** presses on (no threads). Is this the same type of fit as the BMW *****? How could you fit a standard after market theaded **** on to the MINI's shifter? Is it possible? And does it fit right or just mess the shaft up so you can't put the original back on later? Hope someone can help me out. Thanks.
Old Apr 3, 2003 | 02:06 PM
8ball's Avatar
8ball
The design is the same as that of the BMW, but there is a bit of a size difference: I've got the Whalen **** and they figured how to adapt theirs to fit the MINI (PM our own DougW for details).
A lot of the others (MOMO for example) have set screws that clamp the **** collar to the shaft with little damage - when the screw is removed, the stock type still fits.
.... and, yes, a threaded type requires reworking of the shaft ...
Old Apr 3, 2003 | 02:15 PM
'*Ace*''s Avatar
'*Ace*'
WHALEN WHALEN WHALEN!!! I have one and it is nuts...the best mod I have done yet! It is worth the money!!!
Old Apr 3, 2003 | 02:19 PM
Doug W's Avatar
Doug W
Yes, you can do away with the stock mounting method by using one of my *****.
I came up with this idea after buying an aftermarket **** for my own M Roadster, and decided that there had to be a better way of fitting a **** onto the stock shift lever.
I've been selling lots of them to you MINI guys the last few months, and most of them have had custom CNC engraving done to them; shift patterns, screen names, car names, wing designs etc.
See whalenshiftmachine.com for info, or e-mail me at whamac@msn.com
Old Apr 3, 2003 | 03:03 PM
'*Ace*''s Avatar
'*Ace*'
You can also get it engraved like I did. Mr. Whalen does some quality work.
I originally had the Moss Mushroom ****, but it rattled around a lot. This **** stays put and feels great!
Old Apr 4, 2003 | 06:16 AM
Black-n-blue-MCS
Wow, very nice CooperSpeed. Thanks everyone. I've got a much clearer picture of the task in hand now. Mr. Whalen's shift ***** look great.
Old Apr 4, 2003 | 06:36 AM
'*Ace*''s Avatar
'*Ace*'
They feel even better than they look!
Old Apr 4, 2003 | 01:43 PM
mightyMiniz's Avatar
mightyMiniz
Whalen YES
Mine is being Designed right now....
Great product and the quick release is ingenious.
Old Apr 4, 2003 | 01:46 PM
RCristiano's Avatar
RCristiano
I live in SoCal and would have the sunroof. Is that thing going to get unreasonably hot? As long as I don't burn my hand when I touch it I'm OK.
Old Apr 4, 2003 | 01:50 PM
'*Ace*''s Avatar
'*Ace*'
I have used it in reasonably cold weather, and it isn't bad. I can't imagine it would THAT bad. See if there is someone in your area who has a metal **** so you can see.
Old Apr 16, 2003 | 01:22 AM
mightyMiniz
Got Mine This Week!
LOVE IT!
About the heat... TINT YOUR SUNROOF @ 5%!
I'll post a pic of my Whalen soon!
-Doug
Old Apr 18, 2003 | 08:40 AM
binkydognose's Avatar
binkydognose
Got my polished circle 6 speed Whalen yesterday,
Can't believe what a difference it makes, instant love. My wife thinks I'm nutzer 'cause I'm harrasing her by exclaiming "Shift Machine" every so often.
Old Apr 18, 2003 | 08:57 AM
CSP4's Avatar
CSP4
Mine pulled off when I down shifting to second so I put one of these on.
This has a universal adaptor and takes 5 minutes to install. Fits your hand like a glove. I turned it a little off center to the right to adjust fo the angle of my arm to fit my hand perfect. it looks awsome and feels great. This should come standard with the sport package.
Mine has heavy polished chrome at the bottom half.
Old Apr 18, 2003 | 02:49 PM
rfibanez's Avatar
rfibanez
Does that momo **** have screws or does it just snap into place?
Old Apr 19, 2003 | 01:11 AM
CSP4's Avatar
CSP4
The MOMO has set screws. You put a small adapter on, then you unscrew the bottom piece. Next you put the bottom piece on followed by the shift ***. Adjust the angle of the *** to fit the angle of your hand (Your arm is not staight on, a little kick to the right makes it a perfect fit.) Then you screw three set screws in (Come with little allen driver). Last you screw the bottom shaft to the *** and your done.
The MOMO may cost more, but is is form Italy and very well made. You will not regret it. they have many styles, this one is made to fit like a glove. I can feel the shifting more which gives a nice sporty feedback.
_________________
CHRIS
Old Apr 19, 2003 | 01:26 AM
pooky13's Avatar
pooky13
I do agree about MOMO's quality as I own a MOMO Racer seat and "Jet" leather steering wheel in my 92'Honda Civic. Their items are ridiculously expensive but worth it. I may install some MOMO gear in my MCS some months after I get car, who knows! Ractive has some great shift ***** as well. Awesome MOMO shift **** by the way!
Old Apr 19, 2003 | 01:45 AM
mightyMiniz
I might be ordering another WHALEN **** soon! I like the quick release aspect and the option of engravings... I might get my dualM's with the center star.
How about this? Monday, Tuesday, wednesday, etc
Old Apr 19, 2003 | 02:03 AM
Germany's Avatar
Germany
The Whalen **** looks good!! I have about the same size polished aluminum with set screws in my car but what I did was to cut off about an inch off the shaft and installed it, didnt like the looks of the extremly long looking shaft.. now the top of the **** is about on line with the bottom of the toggle switches..Looks really good and shortened the shift throw abit! :smile: inexpensive short shift kit?? :smile:
Have a GREAT day!!
Old Apr 19, 2003 | 03:46 AM
Mini_Street_Racer's Avatar
Mini_Street_Racer
had this on my car for about 12 hours, had to remove it as it sat too high. (need a short shifter to use it) I had to replace it again with the one from rspeed.)
Old Apr 19, 2003 | 01:53 PM
vespa's Avatar
vespa
I extensively modified a BMW ****. I took photos of the process and will post more detail sometime in the next couple of weeks. It sits exactly at the stock height and involved no modifications whatsoever to the stock lever.
Old Apr 19, 2003 | 09:53 PM
CSP4's Avatar
CSP4
You can always cut the shaft to install at stock height. I am 6'3" so I like my seat back. The extra distance helps me shift from darn near the back seat. My best advise is for someone to purchase the style that fits his or her needs best.
Then find the best quailty shift *** at the style they choose. You do get what you pay for.
_________________
CHRIS
Old Apr 25, 2003 | 02:24 PM
Driving_Hamster's Avatar
Driving_Hamster
Just ordered my UUC shift ****. It's well made and should blend perfectly with my anthracite interior. Now if I can avoid giving myself a black eye or a broken sternum while removing the stock ****! Will post pics once it arrives and is installed.
Old Apr 25, 2003 | 04:30 PM
GaryA's Avatar
GaryA
Here is a picture of my Whalen installed. Best modification you can do.
Motor On!
http://www.mini2.com/gallery/personal/gja_era/whalenshifter.jpg"][img]
Old Apr 25, 2003 | 04:33 PM
GaryA's Avatar
GaryA
>>Motor On!
Let's try again.
Old Apr 25, 2003 | 10:29 PM
CSB's Avatar
CSB
I have the Whalen shift **** about 3 weeks now and it's one of the best ***** I've ever had, just the feel in your hand not to mention the looks, it's worth every penny
