Interior/Exterior Downtube (06) removal photo guide?
I know i saw one awhile back and a search here didnt turn it up.
Anyone know where it is on the net? It was a photo step by step guide on how to remvoe the downtubes OR the lower floor cubby/mirror controls
For a lot of things, you don't need to actually remove them:
http://www.gbmini.net/mtblog/archive..._downtub.shtml
Or, ShankRabbit has a great write-up:
http://www.geekshocker.com/Claire/audio/auxJack.php
Pretty easy.
1st - Remove your shift ****, by pulling it straight off with lots of force.
2nd - Remove trim around shifter by pulling it straight up.
3rd - Remove two screws that are in the base of the little cupholders below center console.
4th - Remove the two torx screws on the side of the left downtube.
5th - Removet he two torx screws on the side of the right downtube (these also may hold the cupholder in place).
6th - In the hole that was previously covered by your shift boot, reach underneath and push up on the mirror adjustment piece. This is tricky to do because the mirror adjustment piece is held in place by 6 copper pieces.
7th - Once you remove the mirror adjustment piece, you are better off just unplugging it completely to get it out the way. Then, remove the two screws that are now visible.
8th - You can now remove the whole console in order to slide the downtubes out the bottom.
And for Automatics...?
Originally Posted by rameeti
I didn't get past 1st base cuz I have an automatic and this seemed to be a problem follow.
Spank
11
Apr 9, 2020 02:23 PM
AdrenaliNate
Aug 24, 2015 12:37 PM
minipopkart
Aug 13, 2015 05:22 AM
