Interior/Exterior Driving Lights
Old Mar 21, 2006 | 06:16 AM
qwertmonkey's Avatar
qwertmonkey
Driving Lights
(Sorry for the tacky name on the pic) I just bought these and thought that they were a steal! Are there any pros out there that see a con to them? I was a little skeptical, so some positive feedback would be nice! Thanks!
Quality S.A.E. approved round ~6" halogen lamps creates a precision fog beam pattern with a total of 110W total! Contemporary styling gives it the popular aerodynamic look. Engineered crystal-glass lenses & multi-surface reflector produces maximum candle power output.
Does kit include everything I need? Yes kit includes 2 lamp enclosures, powerful H3-55 watt bulbs, fully adjustable mounts for bumper or bar, harnesses, pre-assembled wiring harness with relay and fuse, micro electronic switch, mouting hardware kit, installation instructions, and more.
I'm not good with electronics, can I still install your kit myself? More involved installation may require drilling or cutting to position the lamp where you want it. The end result will have a clean look if done with care. We recommend professional installation at your local stereo shop for those uncomfortable installing on their own.
Can I hook the lights up to my factory light switch instead of the included switch? Of course, just run the wire to the factory switch instead of the included switch.
What type of bulbs come with your kit? Two powerful H3 bulbs with an output of 55 watts a piece, 110 watts total! These bulbs are designed for maximum output and durability. The bulbs generally last many years without the need for replacement. There is a good chance the bulbs will outlast the life of the vehicle. H3 is a common size bulbs and can be attained anywhere automotive bulbs are sold.
Old Mar 21, 2006 | 06:35 AM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
Looks like you might need the brackets to mount them properly. Otherwise look pretty nice.
Old Mar 21, 2006 | 06:41 AM
qwertmonkey
It says:
Will that work?
Old Mar 21, 2006 | 06:57 AM
Uncle_John's Avatar
Uncle_John
I would consider light mounting brackets from Mini Madness. As the kit stands now, all the parts are there to mount to a horizontal surface. YOU have to provide that surface . . .
Old Mar 21, 2006 | 07:30 AM
SonicVI's Avatar
SonicVI
There's no such thing as "crystal-glass". Who knows what else they're lying about. Just kidding, they look pretty cool.
Old Mar 21, 2006 | 07:36 AM
fishbulb's Avatar
fishbulb
be careful with the quality of the electrical components - switches, relays, etc.
I have had three PIAA relay's melt in three different situations (twice in my car, then once in a buddys) And PIAA is a "brand" name....
Don't know how much you paid, but you should be able to do a full set of Hella 500's for around $100.
-jac
Old Mar 21, 2006 | 08:05 AM
qwertmonkey
-jac
Sorry, I forgot to add that I paid 60.
Old Mar 21, 2006 | 08:49 AM
Crashton's Avatar
Crashton
Not a bad price. If the ones in the picture are like the ones that you have they are driving lamps not fogs. If they were fogs they'd have a lot of fluting in the lens to spread the beam out.
Old Mar 21, 2006 | 08:58 AM
eVal's Avatar
eVal
Yeah, its confusing as to the type of light since it states that its a fog light but looks otherwise... Be sure it is what you want. I hope it works out for you, I personally would be leary of electrical stuff unless it has a warranty/good vendor standing behind it.
Old Mar 21, 2006 | 10:38 AM
mistro's Avatar
mistro
The Driving Lights that Mini Dealers sell and install. Who makes them?
Old Mar 21, 2006 | 03:03 PM
chows4us's Avatar
chows4us
I would be wary of a couple of things. Remember, you usually get what you pay for. As others have mentioned, you dont know the quality of the relay ... what is the mounting mechanism? How are you going to bolt these on?
What "factory switch" The factory switch for driving lights are a separate plastic switch just like the one they are probably sending you ... not in the bank of silver switches (which I dont think are real switches anyway). I know it says fogs but they look like driving lights ...
Old Mar 21, 2006 | 03:13 PM
Crashton's Avatar
Crashton
You could wire them in to come on with the high beam. Make sure & use a relay, also be sure to use a fuse in the circuit.
Old Mar 21, 2006 | 03:19 PM
skuzy's Avatar
skuzy
got a similar set if u want them $100 to your door. (new in box)
same specs as piaa.. everything included but no mounting brackets.
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
