Interior/Exterior OEM Shift Knob install instructions?
OEM Shift **** install instructions?
I've searched and found plenty of instructions for the brute force method to remove the OEM shift ****. But I couldn't find anything about how to install another OEM shift ****.
I'm picking up my MCS on Saturday. If it's easy (i.e., no tools, glue, etc.) I want to replace my stock **** with an already purchased CR **** to match my CR interior.
So is it anything other than slam it on? I also don't want to be stuck driving 400 miles home with a half-assed shift **** application -- or worse, w/o a shift **** because I pulled an idiot move.
--dwf
--dwf
Push
I replaced my stock **** last.
I had to pull hard, but not as bad as I thought.
The **** I put on is one from Moss, and Mini specific, so it had a bar in the top (inside) like the stock ****. Just make sure the bar in the new **** (if it has one) lines up with the notch in the top of the shift lever. The push the new **** down until it seats into place. (Maybe give it a little tap with a rubber hammer to make sure.)
Navigation & Audio MINI Branded nuvi 360 Installation
Super Coop
Aug 17, 2015 05:09 PM
dyeLucky
Aug 7, 2015 07:10 AM
