Interior/Exterior How do you remove the front bumper?
Old Feb 6, 2006 | 07:32 PM
elbum0's Avatar
elbum0
Forgive me, I've never really done any sort of car mod before.
I want to install a replacement car horn, and I gather that to do that I'm going to need to take off the front bumper. Me and my friend are working on it but aren't really sure exactly what to unscrew, etc.
So far we've unscrewed the two top screws and unplugged all those tabs across the top, and we've taken a front wheel off to access another screw toward the top-backside of the bumper, but aren't sure where to go from here.
Thanks in advance!
Old Feb 7, 2006 | 04:26 PM
Nuff's Avatar
Nuff
Removing the front bumper is pretty straightforward. I had to remove it when I installed my aero grill. I used the instructions from motoringfile.com:
http://www.motoringfile.com/howto/MI...ll_install.pdf
The instructions include the removal of the front bumper. Here is the text:
Removing the front bumper cover….
I jacked my MINI up and put it on jack stands so that I could remove the tires. This not only gives you more room to remove the bumper cover, but I cleaned the brake dust off and gave them a good wax before I installed them….
To jack…I used my shop jack. Look under the car and about center point, you will see the body molding protruding downwards. I placed a 2x4, about 2 ft long under that part, to give the car stability. Used the two “jack points” to put jack stands under to keep the car stationary. Repeat on the other side…….
Removing the bumper cover is straight forward. The hex head bolts accessible from the front wheel wells are 8mm, the center three fasteners which attach the bottom of the cover to the bumper are 10mm, and the outer two are Phillips. The top two bolts are TORX T30. As you remove these, keep a hand on the cover as it is only held by a couple of plastic tabs. When you have the cover free, pull it out enough to get to the lighting wires. These are the basic twist on attached and will allow you to completely remove the cover.
Hope this helps.
Old Feb 7, 2006 | 04:36 PM
Teampajn's Avatar
Teampajn
When I'd take my bumper cover off I'd leave the tires on, there is plenty of room when using a 1/4 rachet. I also put a pblanket on the ground to help protect the bumper cover while removing it. Never too much protecting when working around that fragile paint. BTW the 2 bolts by the front wheels to take off are the ones facing up, not forward.
Old Feb 7, 2006 | 04:42 PM
maxmini's Avatar
maxmini
Call me it is a easy deal.
randy
m7 tuning
818 497 4341
Old Feb 8, 2006 | 08:37 AM
mdsbrain's Avatar
mdsbrain
This is very helpful and has pictures
http://mini.uglydoris.com/archives/000020.html
While your swapping the horns you might want to swap to a better fog light bulb too. I know I am.
Old Feb 8, 2006 | 11:27 AM
rkw's Avatar
rkw
The fog light bulb sockets are accessed from the wheel side (by removing the wheel arch liner), not by removing the bumper.
Old Feb 8, 2006 | 01:40 PM
mdsbrain's Avatar
mdsbrain
Once the bumper is off your practically there. Thank you for the correction
FLYM1N1
Aug 15, 2015 11:20 AM
smlzilla
Aug 14, 2015 07:00 PM
JHolland
Aug 13, 2015 10:47 PM
skippermini
Aug 12, 2015 10:05 PM
