Interior/Exterior I want a checker board roof? What to do
Originally Posted by PARTSMAN109
If the dealer sends it out to be done, then it's not dealer installed. It's called a sublet, and then charge you twice as much.
Now i have a relationship with the vinyl installer and bypass the dealer entirely so its even cheaper.
Your mileage may vary.
Hey is the OEM vinyl both colors of checkers (black and white), or is it like one box is clear, and one is white for a black roof, and vise versa. I want to buy one, but need to be sure. Thanks guys
I have had it on for 2 years and I do not garage my car and it looks great still and I wax right over it. I do have 1 or 2 corners that I can just start to see might be lifting (like maybe 1/32" on the corner, barely enough to feel) so I can see needing to replace it in a couple more years. I might get it painted at that time.
I have been trying to find someone to cut some white perforated vinyl squares for me but havent found anyone who will do it. Do any of you have any suggestions?
Also, what size are your squares? I was thinking doing them in 10" squares.
Originally Posted by LeeL
I'll have to go check the size. It ends up being 5 squares across with a small border at the edge.
My squares are 8 1/2 inches. That leaves about a 2" border from the edge of the square to the drip rail. They cut the squares that would touch (front corners especially) to about that same dimension to keep a more or less consistent border all around.
thanks for the measurement.
I am not seeing the 2" of space between your squares and the drip rail that you mentioned. it almost looks as if they either meet up at the edge of your drip rail or even tuck underneath of it?
The red car above has slightly larger or more squares and it does appear to go edge to edge. If you look in my gallery, you can see a white border around hte edge of the black checkers, which is how the official MINI kit looks.
I have never seen one like the red car pictured, it looks pretty cool, especially the back section there.
RobbyD
Jan 29, 2019 01:22 PM
